How to Reset Map
How to Reset Map
Is there a way to recalibrate the map in our PCM? For some reason, it seems like my map suddenly lost its GPS location. Keeps showing I'm driving in the middle of Lake Michigan!
Check to see if the antenna has gotten disconnected. I believe it's located behind/above the rear view mirror.
This happened in my Cayman once. For some crazy reason the antenna connection in it is located just above the cabin filter which is just under the passenger cowling. So, in the Cayman you are practically guaranteed to accidentally disconnect it when you replace the cabin filter. :-|
Bit different issue,
When we were in the high latitudes like Tuktoyaktuk, NWT (69°27'25.7"N 133°01'57.5"W) our nav system would get confused. Instead of showing just the local area it would display from inside Siberia east to Alaska, Yukon and the Northwest Territories. Sure got old zooming in to our actual location. Also glad for Gaia which we actually used to navigate. When we returned to the lower 48 the nav started working as designed.
___________________________
https://rennlist.com/forums/cayenne-...meet-otis.html
kalyan (04-01-2021)
