TPMS System Not Active
Old May 23, 2016 | 12:30 PM
MJP911's Avatar
MJP911
Default TPMS System Not Active
I have a 2008 Cayenne S and have a TPMS warning - "System Not Active." I get no reading from any of the four wheels. Any thoughts or experiences with a similar problem?
Old May 23, 2016 | 10:55 PM
mtnrat's Avatar
mtnrat
Did it work previously? Do your wheel have sensors in them?
Old May 24, 2016 | 07:17 AM
MJP911's Avatar
MJP911
Yes and yes. It was working fine.
Old May 24, 2016 | 07:58 AM
Magnetic K's Avatar
Magnetic K
TPMS have internal batteries that will eventually die, and thus require replacement. Consider yourself fortunate that your original TPMS batteries lasted this long. Replacement TPMS units are not inexpensive.
Old May 24, 2016 | 09:28 AM
mtnrat's Avatar
mtnrat
I got these two years ago for my winters.
http://www.ebay.com/itm/2003-2016-TP...5XIoT~&vxp=mtr
Old May 24, 2016 | 09:31 AM
mtnrat's Avatar
mtnrat
You might try going into your menu and reset the wheel info???
Old May 25, 2016 | 07:29 AM
MJP911's Avatar
MJP911
Tried the reset - did not work. I think it would be a weird coincidence for all 4 batteries to go at the exact same time, no?
Old May 25, 2016 | 10:37 AM
69gaugeman's Avatar
69gaugeman
Yes it would. However small, the chances are that it is possible. Needs to be hooked up to PWIS or durametric (or I think even VAGCOM would communicate) to see why the message is there. I know on my 04 Touareg you could actually shut off the TPMS. not sure if that is possible on the 08's
Old May 25, 2016 | 02:09 PM
Brit6's Avatar
Brit6
I had the same problem one time. Your really need a PIWIS to reset it and it will also tell you the battery life of the sensors!
Old May 26, 2016 | 07:37 AM
MJP911's Avatar
MJP911
Thanks to all.
