Temperature needle fluctuates?
Received 1,153 Likes
It's located on the fan assembly. The whole mcgilla is sold as an expensive single item, both fans, the control module and housing. Some people have reported replacing the fans with ones used on a Ford IIRC.. but it's a long time ago that I read about that.
Thanks I saw a picture of the fans and thought it might be that metal box thing on there. I guess this is good news and bad news.
Hmmm... if nobody else has tried, I’m going to see if repair of the module is possible.
Thanks!
Thanks!
Today, my 03 turbo coolant temperature steadily read 185 F (85 C) normally while moving and happy.
I monitored the temp with the OBD feature of my iCarSoft.
At long enough red lights, the gauge would slowly and slightly gradually creep over to the right in direct proportion to the increase in temperature displayed on my OBD reader. There was no dead spot.
It would typically get up to around 190 before the traffic light would turn green.
When I got home, I let it idle to observe how hot it would get.
I let it get up to 199 F and then checked to confirm the fans were off. (I could only see the RHS fan, but it was quiet and I'm sure the left fan was off too).
After switching off ECONOMY with the unit set to low for the AC to come on, the RHS fan turned on and the coolant temp immediately began to drop. Back to 185 in less than a minute.
After looking at the Pelican write-up, I'm sure I never disconnected the plug to the left side fan.
Where is the fan control module located?
Does it need to be coded?
Is there a fuse or relay I can check first?
Thanks.
Thanks.
Thanks J, I'll do a search.
Stefan, I'd like to be encouraged... but after the agony I went through making my coolant system well again, I'm like an overprotective mother and cringe at the thought of over-pressurizing the system due to high temperature.
I still need to get to work and have the ability to run my AC and/or heat with the windows open if things go south, so I have some more time to test things out while keeping an eye on the temperature.
At what temp is it obvious there's a problem, though? I don't see why Porsche would set the threshold for the fan activating at anything above the middle of the gauge.
Plus the temps are only in the mid 50's right now. I'm sure my gauge never moved from the middle last summer with temps in the 90's. (Although I would have had the AC on then which turns on the RHS fan).
Anyway, I'll definitely post anything new I discover.
Thanks.
Thanks.
Thanks.
Thanks.
Thanks for all the details. I’m reassured to at least carefully go on with my observations and verify I never exceed those maximum values you mentioned.
Confirmed
I still swear my Cayenne never behaved like this last year, but...
So I drove home and parked in my driveway and let the car idle for about a minute or so with the climate control off. 68 degrees outside.
The temp steadily climbed and within a couple of minutes went from 185 to 204 F. with the needle at a menacing incline that would ordinarily have me freaking out.
That’s as warm as it got before pretty steadily going back towards the center.
I let this cycle of ramp-up and cool down continue with the hood open and observed that even the RHS fan turned on (with the AC off).
I couldn’t see, but it also sounded like the LHS fan came on too.
So there you have it. Odd but apparently ok.
f266 (02-14-2021)
It's also possible that the behavior of the 955 is different than that of the 957. In the 911 series of similar vintages, the 996 (99-04) had a true coolant temperature gauge, but the 997.1 (05-08) has a heavily buffered gauge - if the 997.1 gauge ever goes past center, you're in trouble. Center is 175 degrees and true coolant temp could actually be in the low 200s.
In my 957 TTS, I can tell you that the gauge is also heavily buffered as I have p3cars vent gauge where I can monitor actual coolant temperature from the obd2 port. In a fully warmed up situation and normal driving, the actual temperature is between 180-185 F and the needle on the dash gauge is between straight up and just a tick past straight up.
When the car gets hot - climbing a mountain with a lot of boost, sitting in traffic, etc, the true temperature will get as high a 214 F before it starts cooling down with the fans engaging, but during this time, the needle on the dash gauge still only shows that tick past vertical, even though it should be well beyond that at 210-215 degrees F.
Here's the p3 vent gauge (left side) showing 188 and the temp needle at the standard position.
“passes everything but the gas station”
Cool. No pun intended. Had no issues yesterday with temps near 80.
Even heard the fans on after turning the engine off.
Took this pic.
Took this pic.
First time I helped myself with a post from the past.
So with the quarantine here in NJ one of my ways of keeping sane is, on sunny days once in a while, I go for a little drive in my beautiful Cayenne.
Sometimes just to go to the McDonald's drive-thru to get a diet Coke.
So I'm waiting in the drive-thru and notice my temp needle creeping up pretty bad.
I shut off the engine etc. make it home and look at it for the next few days.
I once smelled a whiff of coolant after one of these events. So I figured my water pump was going bad and bought the parts and was going to do the job but its been rainy lately.
Anyway, I just figured I'd look back at my old post from last year and do another test.
Sure enough, the temp numbers I observed from last year were exactly the same.
So long story short, I have the pump and still plan on replacing it along with the serpentine belt, but it's just such a relief to know I still have my pig to rely on during this pandemic and can put it off a bit longer.
I still have a slight coolant leak somewhere but in a year's time it hasn't gotten any worse at all.
It's interesting that this problem only manifests itself in the spring when it's not hot enough for the AC to come on but not cold enough either. (another reason I really hate that stupid Economy button as opposed to an AC switch)
By the way, I'm not convinced this is the way the car was designed... or maybe somethings off, but the fans still both work and the 2nd one comes on right at 204° F and cools everything down.
