Oil Leak on CT 2004
Oil Leak on CT 2004
Hi,
Last week my Cayenne Turbo 2004 with 225K started showing signs of oil leak on the
passenger front side. Oil drip residue after parking varies from none to 5x5 cm circles. Most of the time it happens, but not always. Not linked to style of driving as far as I can tell. Valve Covers both sides replaced a couple of weeks ago.
Pulled the engine cover this Friday and cleaned out both charge pipes. Driver side contained around 1-1.5 DL, while the Passenger side was dry(as expected I guess). With the charge pipe removed it looks like the oil is dripping from
above as there is oil buildup on the air intake pipe as well. Oil is spilled all over the place to be honest, so not easy to pinpoint. Any ideas of what I can be or what I should check next?
I tried snapping some pictures, but not easy to get a good one.
