Tire Stem Valve Caps
Old 01-08-2014, 06:09 AM
dandelos
dandelos's Avatar
Question Tire Stem Valve Caps
Lost the two rear caps and since then the left rear tire has been losing pressure too quickly (i.e. 45 to 37 drop within a week). I know the caps aren't really supposed to prevent pressure loss as much as keep the stem valve clear of mud and debris, but who knows. Might be a nail, though the tires are worn and are due to be changed anytime now anyway.
And writing this it just occurred to me that I could transfer the front caps to the rear to test the pressure loss theory out. Oh well...
In any case, does anyone have any recommendations for good and cheap tire stem valve caps that I can get? I read that metal isn't recommended, as different alloys might bond over time, so I should stick to plastic?
Thanks in advance!
Old 01-08-2014, 08:25 AM
Frank 993 C4S
Frank 993 C4S's Avatar
You could not tighten the valve caps tight enough in order to keep 30+ psi in the tire so it's probably a nail. On TPMS systems use plastic caps only.
Old 01-08-2014, 09:27 AM
XR4Tim
XR4Tim's Avatar
I have seen ice form in valve stems, preventing them from sealing all the way. This is a possibility with your cap missing if you're in a cold climate.
Old 01-08-2014, 12:10 PM
Renn 951
Renn 951's Avatar
Make sure the valve core is screwed in tight. With the cap gone, some foreign object might have gotten in the stem and loosened the core just a bit.
Old 01-09-2014, 03:20 AM
dandelos
dandelos's Avatar
Noted, thanks!
Moderate SoCal weather here, and car is garaged, so I doubt ice is a factor. Thanks, though.
Will check, thanks!
Old 01-09-2014, 08:37 AM
hahnmgh63
hahnmgh63's Avatar
If you were between the freezing temps drop and you had checked the tire relatively warm and now again with real cold temps that you account for some of it, but of course it would affect all tires equally.
Old 01-09-2014, 11:02 AM
dryadsdad
Team Owner
dryadsdad's Avatar
Received 1,498 Likes on 971 Posts
Thanks in advance!
Caps DO prevent pressure loss. Replace with metal and see if that makes a difference.
Old 01-09-2014, 11:46 AM
DWPC
DWPC's Avatar
Troll or uber-cheapskate?
Old 01-09-2014, 04:43 PM
dandelos
dandelos's Avatar
Me? I can be a troll sometimes and am not ashamed to admit that I'm most certainly a cheapskate (or perhaps to be PC, a deal finder). But it was an honest-to-goodness question/OP. I've seen several caps being sold on Amazon and eBay, and while cost is always a factor for me, quality is also a significant consideration, especially when it comes to our cars. I don't want to buy any ol' set of caps just because they are only a few bucks without being convinced they're the right ones for our needs (durable, won't cause additional issues, etc). So if anyone has any specific cap recommendations I'm still all eyes+ears.
Old 01-10-2014, 12:26 AM
DWPC
DWPC's Avatar
Caps protect the stem valve from dirt/debris; the "seal" they provide may help slowing loss in a complete valve failure. Replace the stem valve at a local tire store.
Quick Reply: Tire Stem Valve Caps
