Need help with price..
hi, I'm looking into buying this 2006 cayenne s , the owner is asking for $22k, is this a fair price?the vehicle has 62k miles, one owner with a clean title and the 60k miles service was done 3 weeks ago with a cost of $1200, here are the options on the cayenne.
* * 2006 Cayenne Tiptronic * * * * 9PA * *AD1 * * * * * * * * * * * * Price
* * * * * BASE * Porsche Base Model * * * * * * * * * * * * * * * *42,200.00
* * * * * E4 * * Carmon Red Metallic * * * * * * * * * * * * * * * * *495.00
* * * * * E4 * * Carmon Red Metallic Top * * * * * * * * * * * * * * * *0.00
* * * * * LV * * Havanna Sand Beige Leather Int * * * * * * * * * * * * 0.00
* * * * * G0R * *Tiptronic S * * * * * * * * * * * * * * * * * * * *3,000.00
* * * * * CJ6 * *18" Cayenne Turbo Wheel * * * * * * * * * * * * * *1,340.00
* * * * * H9M * *All-Season Tires on 18" Rims * * * * * * * * * * * * * 0.00
* * * * * PC3 * *Bi-Xenon Headlights w/ Washers * * * * * * * * * * 1,240.00
* * * * * 0TD * *Front and Rear Floor Mats * * * * * * * * * * * * * *130.00
* * * * * 3X1 * *Ski Bag * * * * * * * * * * * * * * * * * * * * * * * *0.00
* * * * * 7X2 * *Front and Rear Park Assist * * * * * * * * * * * * * 990.00
* * * * * PPA * *Preferred Package * * * * * * * * * * * * * * * * *3,060.00
* * * * * PO4 * *Light Comfort Package/Memory * * * * * * * * * * * * 610.00
* * * * * 3FE * *Moonroof * * * * * * * * * * * * * * * * * * * * * * * 0.00
* * * * * 1D6 * *Trailer Hitch w/o Hitch Ball * * * * * * * * * * * * * 0.00
* * * * * PG1 * *Driver Seat Memory * * * * * * * * * * * * * * * * * * 0.00
* * * * * 1NP * *Wheel Hub Covers Colored Crest * * * * * * * * * * * * 0.00
* * * * * 9AD * *Automatic Climate Control * * * * * * * * * * * * * * *0.00
* * * * * 342H * Front Seat Heater * * * * * * * * * * * * * * * * * * *0.00
* * * * * * * * * * * * * * * * * * * Total with Options $ * * * * 53,065.00
* * * * * DSTCHG Destination Charge * * * * * * * * * * * * * * * * * 815.00
* * * * * * * * * * * * * * * * * * * * * *Total Charges $ * * * * * *815.00
* * * * * * * * * * * * * * * * * * * * * * *Total Order $ * * * * 53,880.00
Your help will be appreciated
Received 1,151 Likes
If it's for an S (not clear since it starts out as a base Cayenne Tiptronic).. price seems fair. I don't see the PCM/GPS/Bose audio, which add some value. Of course that gives you an opportunity to upgrade the existing audio without having to deal with the MOST fiber system.
Since it has no warranty, you want to set aside $3,000 or so to address any issues it might have (like the engine coolant pipes.) I'd also suggest a PPI by a good Cayenne independent or a dealership.. the cost will be trivial to what it might save you.
Reading the threads on common problems might also be useful..
I will get a PPI done this week and see what happens, also he installed new rotors and pads @ 50k miles
Also have you asked the seller if they have had the coolant pipes replaced?
If so ask if the vehicle stopped because of burst pipes or was it preventive. could have caused engine damage so when you get the ppi completed get cylinders tested for comp.
There is a good thread as to how to check if it was done with a mirror and flashlight, just search "coolant pipes" and you should get enough reading to keep you occupied for a few hours : ) .
Called the owner and told him I will take the cayenne and which Porsche dealer was the closest to him to get a PPI, NEVER HEARD FROM HIM AGAIN...
I will honestly say that I've seen fewer problems with Turbos. If you are looking at 955s, newer is going to be better, so 2006 would be ideal, though nothing really changed between '05 and '06 except for the addition of the Turbo S model. 2003-2004 models had lots of minor problems that were corrected with updates along the way. At this point most of those will likely be taken care of already, so I wouldn't avoid those all together (provided the vehicle has been maintained and passes a PPI).
I will honestly say that I've seen fewer problems with Turbos. If you are looking at 955s, newer is going to be better, so 2006 would be ideal, though nothing really changed between '05 and '06 except for the addition of the Turbo S model. 2003-2004 models had lots of minor problems that were corrected with updates along the way. At this point most of those will likely be taken care of already, so I wouldn't avoid those all together (provided the has been maintained and passes a PPI).
Pretty much my P!g except I've got PCM/NAV and 5k more miles. Sad to think I could only get $22 - 24K for it retail. Scared to think what they would offer me wholesale.
BILL, it looks to me that you are crazy about burgundy porsche's
Well you are not the only one my friend
