reversing camera
Old Apr 6, 2016 | 03:59 PM
  #166
zonnie's Avatar
zonnie
Originally Posted by morrisdl
I have a couple of those pigtail cables that I didnt end up using in my install (wrong gender). You are welcome to them just pay the shipping and Ill get them out. PM me.
awesome! care to clarify what pigtail cables are? does it come with the camera I bought?? how do i know they'll fit for me?
excuse my amateurness...first timer!
Old Apr 6, 2016 | 05:07 PM
  #167
morrisdl's Avatar
morrisdl
I have two of there RCA female to Fraka pigtails:
Old Apr 12, 2016 | 01:13 PM
  #168
jodyodom's Avatar
jodyodom
5th Gear
Default Cayenne 06 Turbo reversing Camera
Originally Posted by hahnmgh63
You only need to get the PCM coded for the AV input to work. I just went through this on my '06 Turbo S when the OEM camera failed and Porsche wanted over $1500 for a new camera/telescoping motor setup (my motor still worked fine). The control box on OEM equipped Cayennes only controls the motor and supplies the voltage (6.5V) for the camera. The camera output signal goes through a FAKRA connector all the way to the front and connects into the back of the PCM. I hooked up a 9V batter to an Ebay camera and plugged it in directly to my PCM through a RCA video to Fakra adapter and the camera worked as good or better than OEM. I just adapted the mounts for the OEM telescoping setup, figured I might as well use it since it was there and worked. Many of the aftermarket kits just replace one of the license plate lights with a angled camera. You will need your PCM coded for the backup camera if it didn't have it before. My OEM PCM failed and I bought a newer (2007 PCM2.1) from Ebay and plugged it in and got my dash compass & Satellite radio back but not the A/V. I took it to the dealer and it took 15 minutes or less for them to recode the PCM.
Hi Hahnmgh63, I have a similar issue with my 06 Cayenne Turbo but my camera works on the screen but the telescoping door will not open. This started failing slowly over time and now will not open at all. Do you recall if this can be purchased separately? Thanks, J
Old Apr 12, 2016 | 09:57 PM
  #169
hahnmgh63's Avatar
hahnmgh63
Porsche only sells the telescoping mechanism/motor & camera as a complete package. If you are mechanically inclined you can carefully take the telescoping mechanism apart and clean out the old grease/dirt/corrosion and re-grease the little jackscrews and see if that fixes it.
Old Apr 13, 2016 | 12:08 PM
  #170
jodyodom's Avatar
jodyodom
5th Gear
Thank you Hahnmgh63. My local Euro car mechanic called me this morning. They made another attempt at totally dissembling and cleaning the telescoping motor. It works again now. I suspect this will happen again in the future since I live at the beach where the salty air is more than likely the culprit.
Best, J
Old Apr 16, 2016 | 04:14 AM
  #171
hahnmgh63's Avatar
hahnmgh63
Glad to see it worked out. I disassembled and cleaned mine over 3yrs ago and it still functions like new.
Old May 17, 2016 | 02:57 PM
  #172
zonnie's Avatar
zonnie
havent installed the camera yet,
the indy activated the reverse camera with no issue,
only thing is when I put the car to reverse then into drive the back up screen still appears for a little while before the PCM displays the main screen
how quick should the back up camera screen appear after going into reverse?
how quick should the back up screen go back to main screen after back to drive ?
Old May 17, 2016 | 09:37 PM
  #173
hahnmgh63's Avatar
hahnmgh63
Swaps out of the camera mode at about 10mph or when you swap to any other mode, or setting the parking brake when stopped.
Old May 23, 2016 | 03:22 PM
  #174
John Veninger's Avatar
John Veninger
Anyone have a link to a current camera on ebay that works with 6.5v?
Most say 12v +/- 10%
Old May 23, 2016 | 03:57 PM
  #175
zonnie's Avatar
zonnie
i just bought this one, waiting for it to be shipped. i believe the mounting holes need to be enlarged a bit to fit the cayenne as most have previously discussed.
http://www.ebay.com/itm/151460788774?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old May 23, 2016 | 04:15 PM
  #176
John Veninger
I would like to use the original location. Was looking at this one, but not sure if it will run on the 6.5v.
http://www.ebay.com/itm/Waterproof-1...0AAOSw6kxXIGrs
Old May 23, 2016 | 04:30 PM
  #177
zonnie's Avatar
zonnie
what year is your cayenne? isnt the original location the one that pops out of the rear wiper blade area?
Old Jun 7, 2016 | 03:57 PM
  #178
zonnie's Avatar
zonnie
i cant see my bumper from the rearview but i guess since this was only a 100 dollar mod i can't expect much.
I have the lines though... any tips on how to get them to line up better?
Old Jun 8, 2016 | 04:41 PM
  #179
zonnie's Avatar
zonnie
The reverse camera comes on when I put it in reverse however
1. I can't activate it manually by pressing AV button
2. After putting it into drive again, I get the black screen that says "camera does not replace looking over shoulder" for a while.
Is this right?
