V8 Torque Covertor Seal
Hi,
I discovered some leaked from this seal and wanted to replace it.
According to the mechanic, it needs a lot of job and hv to lift the engine first before can reach the torque convertor.. unlike V6.
Any advice are appreciated.. What is the best way to replace this seal.
Had it done recently on my 04 CS. at a indy shop Cost around $1100. to replace a $50 seal. Cost is obviously in the labor to remove the transmission to get to the bell housing where the seal is at. This procedure which is still a 10 hour job does not require lifting the engine.
I haven't looked under the Pig lately but do you have to pull the Turbos to get at the bell housing? If not then it seem like it couldn't be too bad for someone with a decent shop.
He tried actually for fews hours and this is the answer he given me
The old procedure for a replacement of a torque converter seal for a V8 Cayenne requires lifting the engine and separating the transmission to unbolt the bell housing from the engine. The new procedure now does not require the engine to be lifted. This is now accomplish by using a special tool available through Porsche to reach the top bolts of the bell housing (tight fit) with the engine in. I used a independent service repair shop that used this newer procedure. Keep in mind that you are still looking at a minimum of 10 hours even with the correct tools and lift.
