Noise from wiper blades
I second the Porsche additive -- MB sells an excellent one also. I believe it is really to foam correctly for the headlight washers but it lubricates the wipers/windshield. I give it a little hit every time I run the wipers.
<snip>
And the Porsche fluid when mixed with water will not provide freeze protection -- so just like the mercedes additive -- you need to add it to windshield fluid suitable for low temps. The Porsche bottle is not clear on this point.
<snip>
He recalled (and then I did too) the 928 had a separate fluid tank for just such additives and we wondered if this is intended for the 928's two tank system rather than the Cayenne's single tank.
Can anyone shed any further light on this subject?
Thanks,
--Bob
Received 1,153 Likes
I mixed it with standard blue ($1.99/gallon at KMart) windshield washer antifreeze and it worked just fine. It also notes on the concentrate bottle if you read the tiny itty-bitty print, that it doesn't provide any freeze protection and should be used with washer antifreeze. I think what it really means with the warning is - don't use it with another cleaning solution. The blue stuff in the gallon jugs is just water, alcohol and some blue color dye. It has no real cleaning properties beyond what water does.
My experience with parts-counter-guys has been mixed. Some are pretty smart and if you throw a problem at them they'll say, "Oh, frammis has failed, you need a muffler bearing and blinker fluid.." and be correct. They learned by watching what the mechanics ask for. Other ones are not the brightest bulb in the pack and will make stuff up just to sound as if they're the first guys.. Very mixed bag asking them for advice.
Update: I just looked at the concentrate bottle. I could not find any itty-bitty print about not providing any freeze protection and that it should be used with washer antifreeze. Are we talking about the same stuff?
Looks like the same stuff - different label: http://www.pelicanparts.com/cgi-bin/...r%20Booster%29
Note what it says: "Eliminates wiper blade rattles and squeaks by utilizing advanced lubricants in its formula which reduce wear and tear. Can be mixed with any antifreeze washer additive. Environmentally friendly formula is biodegradable, phosphate-free, and formalin-free. Does not leave white residue on paintwork. 250ml"
Ah - found it. It's in a TSB available on RennTech. You can probably see it in this thread: https://rennlist.com/forums/porsche-...her-fluid.html
The TSB specifically suggests using it with phosphate free antifreeze solutions for winter use.
I knew I saw it somewhere..
