Losing boost while accelerating
'06 Turbo S, 23k miles. The car is losing boost when I accelerate. I give it throttle, I watch the boost gauge go up to .8, then suddenly the car hiccups, boost gauge moves around a bit and settles at .4, acceleration continues but at a slower pace. Orange engine light flickers while the boost gauge is moving around.
It seems like it's losing boost, like it can't maintain such a high bar load.
This happens at all times, whether from 0mph or 80mph. The hesitation is exacerbated in 6th gear in "manual" mode when I give it full throttle and it can't downshift.
Any ideas as to what's going on, and how I can fix this?
The dealer's diagnosis matches yours. They're replacing coils and covering labor under a kind of courtesy extension of the original warranty, but I have to pay for plugs and its labor. Also planning on having them do coolant pipes as a precautionary measure; hopefully their quote comes out to be reasonable.
Your dealer sounds to be good people covering your coils out of warranty or just out of warranty. As for the labor, well it is what it is and it's expensive. You may want to arm yourself with coolant pipe info and make a fuss. You could find yourself paying only the labor for that as well.
