WOOOHOO Workshop manuals, Codes & Parts for $15 & Durametric
Got them from xxx xxx xxx
Works perfect, I feel a little stupid for spending already $25 on the porsche website.
Also got me the durametric yesterday![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Already solved :
P0348 : it wasn't the sensor but a wire loose in the connector.
Next up :
P1314
P1299
P0907
Already solved :
Next up :
P1314
P1299
P0907
Last edited by 911SLOW; 02-17-2011 at 08:44 AM. Reason: Posting material or links to material violating copyrights is not allowed
Admin
Fault code 1299
Gateway
Diagnostic conditions
• Ignition on
• Trailer hitch control module, internal function test
Possible causes of fault
♦ To localise the fault, read out the fault memory for the 'gateway
control module' (please read out fault memory)
♦ No message from gateway on CAN comfort (no signal/communication)
♦ Trailer hitch control module faulty
Affected pins
Trailer hitch control module, plug B:
♦ Pin 8 'CAN comfort (low)'
♦ Pin 7 'CAN comfort (high)'
Work instruction Display OK If not OK
1 Check fault memory in the trailer hitch control
module for further faults
Further faults present
Correct the faults
Step 2
2 Read out fault memory for gateway (fault localisation)
Work through faults
Step 3
3 Continue troubleshooting in the chapter
'Checking instructions/CAN data bus
Fault code 0907
Load management operation on vehicle electrical system/
DME control module
• Ignition on
• Internal control module function test
• Load management is coded
• Engine running
• Engine speed approx. 2000 1/min.
♦ 'no display' Loads are/were switched off temporarily. The load
management operation was enabled because of undervoltage.
The DME control module receives the analogue signal from terminal
'DF' on the generator and sends the evaluated information to the
CAN drive. The vehicle electrical system control module determines
the situation of the vehicle electrical system based on the battery
voltage, the 'DF signal' received via the CAN comfort and the heavy current
loads with short operating time. A fault is detected and a
fault bit is set if the 'DF signal' falls below a defined value during a
critical vehicle electrical system state. If the fault bit remains set for
more than ten seconds, the fault 'Load management operation on
vehicle electrical system/DME control module' is stored in the fault
memory of the vehicle electrical system control module.
Affected pins
Plug 'A' on vehicle electrical system control module:
♦ Pin 1 'CAN comfort (high)'
♦ Pin 2 'CAN comfort (low)'
1 Check battery:
2 Check charge voltage/
current on
three-phase generator:
• Vehicle engine speed
approx. 2000 1/min.
11.4 - 14.4 V
Step 3
Wiring/regulator or diodes
faulty.
3 Check DF line for
short circuit to B+:
♦ Switch off the ignition.
♦ Pull out plug 'A' on
SME control module.
generator.
♦ Switch on ignition.
♦ Measure voltage in
SME control module
plug'A' 'Pin 28' to
ground.
< 0.3 V
Step 4
Repair / replace wiring harness
→ End
4 Check DF line for
short circuit to
ground:
♦ Measure resistance
in SME control module
plug 'A' 'Pin 28' to
ground.
∞ Ω
Step 5
→ End
5 Check DF line for
open circuit:
between SME control
module plug 'A'
'Pin 28' and generator
plug 'A' 'Pin 2'.
< 5 Ω
Step 6
→ End
6 CAN test:
• Carry out test according to checking
instructions/CAN data bus (Rep. Gr. 9700):
→ End
Gateway
• Ignition on
Affected pins
Correct the faults
Step 2
Work through faults
Step 3
Fault code 0907
DME control module
• Ignition on
• Engine running
Affected pins
1 Check battery:
current on
approx. 2000 1/min.
11.4 - 14.4 V
Step 3
faulty.
3 Check DF line for
SME control module.
generator.
SME control module
plug'A' 'Pin 28' to
ground.
< 0.3 V
Step 4
→ End
4 Check DF line for
short circuit to
ground:
ground.
∞ Ω
Step 5
→ End
5 Check DF line for
open circuit:
between SME control
module plug 'A'
plug 'A' 'Pin 2'.
< 5 Ω
Step 6
→ End
6 CAN test:
→ End
Super Moderator
Needs More Cowbell
Needs More Cowbell
Received 1,149 Likes
I'm just guessing - the moderator may have removed the link since forums don't like getting nasty threatening lawyer letters when people post info on obtaining ILLEGAL copies of copyrighted materials.
If not - they should. It's no different from stealing from your neighbor.. someone gets paid to produce the copyrighted material..
Ah - didn't spot it the first time:
As a sometime author of copyrighted materials - THANK YOU 911SLOW!
Last edited by 911SLOW; 02-17-2011 at 07:44 AM. Reason: Posting material or links to material violating copyrights is not allowed
Admin
I knew you 'd notice that! It's Pavlovian and apparently works through dead people. (say hi to Larry) ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
BTW Kostantin is Greek too.
www.rennlist.com
www.renntech.org
Exactly. Thank you.
According to the site's rules, if it is copyrighted material, it’s fairly cut and dried; no distribution of illegal copies is allowed.
Not to mention, it's unfair to those of us that pay serious money in order to gain proper access to the official PIWIS.
On the other hand, as I said before, I don’t really like this money making policy (and over-protection from independent Porsche specialists), from Porsche’s side, and I believe that the workshops manuals should be free (or with a symbolic fee) and should be given to the original owner at the time of purchase.
www.rennlist.com
www.renntech.org
Fault code 0907
Thanks 911slow. Now I just have to find teh time to check this. I fly this nicht to >Uk then come back the same day then we have racing but on Monday I should find the time to check this.
I hope it helps!!!
Konstantin
I hope it helps!!!
Konstantin
