Light Bulb Issues-Is this common?
Every few days I get a light bulb out warning. It seems that the 2 head light units are not sitting snug, and when I go over a bump or lightly knock the units the turn signal or low beam goes out.
Does anyone have a solution for this?
Thanks in advance.
Sam
Thanks in advance.
Sam
Super Moderator
Super Moderator
Needs More Cowbell
Needs More Cowbell
Moderator !x4
There are screws that come loose over time on the headlamp base plate, its a DIY job. Also if its turn signal related bending the contacts up can help a lot
I called PNA, they have no idea what a TSB is, and referred me back the stealer. I called them, and they have no idea what I am talking about.
Rocky Mountain High
Use some Loc-tite on the them when you tighten them up, and they should stay put. I think they are 10mm bolts.
