Coolant pipe replacement
Old 09-08-2010, 12:30 AM
heypete
heypete's Avatar
Default Coolant pipe replacement
I keep reading about the coolant pipes needing to be replaced at some point. When were yours replaced and in which model?
I have an '06 CT with 50,000 miles, has not been replaced yet.
Old 09-08-2010, 11:01 AM
Cole
Cole's Avatar
They are mostly in 03-06 CS/CTT/CTTS and happen at any mileage. Your's could blow tomorrow or at 150K miles.
There are two things to know.
-When it happens you will probably be far away and need an expensive tow.
-The Torque converter seal often follows the coolant pipe failure. (gets coolant on it, it drys to sand paper finish and tears into the seal).
Changing the coolant pipes now is a $700 to $1,2000 ish bill ($700 ish for all the parts if you DIY).
If you wait to add the tow bill and the TC seal swap you could easily add $2k+ to that bill).
Old 09-08-2010, 12:06 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,451 Likes on 905 Posts
'04 CS with 72K miles. Still on my original plastic pipes.
I'm considering having them changed as a preventative measure, but I haven't gotten around to it yet.
Old 09-08-2010, 12:20 PM
Cole
Cole's Avatar
FWIW, my 04 CTT popped the coolant pipes at 72K miles at the top of Loveland Pass in Colorado. Had to leave the CTT in Keystone for the night. All the tow companies wanted $700-$1,000 to tow it from Keystone to Denver.
Unfortunately the "road side" assistance I have/had will only tow to the NEAREST "Repair facility", not the nearest "PORSCHE" repair facility.
A friend with an auto body shop sent one of his tow drivers to go get it for me for "only" $350.
Old 09-08-2010, 04:14 PM
Clutch-n-Throttle
Clutch-n-Throttle's Avatar
That's what I was planning to do. Unfortunately, mine popped sooner than later
Old 09-08-2010, 05:16 PM
Cole
Cole's Avatar
Wink
You might consider giving 3Zero3 Motorsports a call. 303-456-8383. Talk to Scott or Max. Let them know I sent you and they are usually pretty friendly. Great guys and do very good work for a reasonable cost.
Probably at least worth getting a quote.
Old 09-08-2010, 06:14 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
I've actually already spoken to Scott about some potential mods for the 911. I'll contact him about the pipes too - thanks.
Old 09-08-2010, 06:58 PM
Cole
Cole's Avatar
I wish I had gotten to mine before they broke. Would have saved me about $1,500
Old 09-08-2010, 09:46 PM
heypete
heypete's Avatar
I dunno what to do then.. I have CPO warranty for another two years but barely drive the car now cause I'm in school...the chances of it blowing out in these next two years is likely pretty small
Old 09-08-2010, 11:13 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
I talked to Scott today. He said that replacing them before they burst would run me around $1,300.
Old 09-09-2010, 12:24 AM
yeldogt
yeldogt's Avatar
With the CPO you are covered -- as well as towing the car. But the car will not be drivable - it will leave you stranded.
I had a few issues with my CS that quite frankly made me unwilling to use it to transport my family on any extended trip. It took some patience but Porsche finally did what I asked -- and changing out pipes was one of them.
Old 09-09-2010, 08:51 AM
jr1966
jr1966's Avatar
'05 CTT, 72k miles, original pipes. Scheduled for replacement this December as a preventive.
Old 09-09-2010, 10:18 AM
Cole
Cole's Avatar
When they break they do it in a fashion that you really can't tell how they broke.
When we removed mine we looked at them for hours and never did figure out where the leak was coming from.
Meaning......the dealer won't be able to tell if they are actually bad or not even after removal. If you have the warranty I'd be tempted to pour 1/2 gallon of over the back side of your motor and show up at the dealer asking what it is.
Old 09-09-2010, 10:58 AM
heypete
heypete's Avatar
thats not a bad idea Cole..tell me more haha
Old 09-09-2010, 11:12 AM
Cole
Cole's Avatar
Not really more to tell.
That is really the only symptom of the coolant pipes breaking.(and the light on the dash saying to check coolant level) You can't see them without taking the intake manifold off.
Quick Reply: Coolant pipe replacement
