Trailer towing in Manual Mode only?
I seemed to have read that we should only be using the Tiptronic in manual mode when towing with a Cayenne.
I read my owners manual and cannot find any such instructions.
While I understand it may be better to prevent constant 6th to 5th downshifts is this really a factory recommendation and any links would be much appreciated?
TIA
TIA
I seem to remember someone here actually caused a few trans issues by using manual mode while towing.
I think only in extreme downslopes or upslopes you might want to use it. Orhtewize i would just leave it in drive.
TIA
TIA
Leave it in "D" and use your thumb shifters to keep your Cayenne from upshifting into 6th too early. You want to try and keep the engine in the power band if possible - anything above about 2500 RPM.
Manual mode will allow you to start in 1st and avoid 6th gear (at 40mph) which is good if you're towing some weight. An empty trailer (like I had in my pic) or light weight I'd leave in drive. I would avoid downshifting to a stop in manual mode (towing or not) as the P!g downshifts itself regardless and I've found it to down shift more gears than I would want by accident (it downshifted and I hit the button) which could actually be bad for the tranny if you're towing. Brakes are cheaper than transmissions!
Super Moderator
Needs More Cowbell
Needs More Cowbell
Super Moderator
Needs More Cowbell
Needs More Cowbell
Obviously those instructions are next to the section on "Check Trailer Lights" and "Recommended Trailer Electrical Configuration/Load"
It is caused limited liability....you haven't lived until PCNA looks you in the eyes and considers the possibility that you may have voided your warranty by towing with your Cayenne...although there is no written reason why you may have actually done so....
When I tow my Big trailer(28ft flatbed) with a car or toys on it I use Manual to the control everything more and since I dont have a trans temp gauge yet to see what the temp gets to when really working the trans... but my little trailer(15ft flatbe with rails) I just leave it in "D".... I would like to get a Bigger trans cooler but I think I need to find one that will work.. Or just get another factory one and run them in series...
Carl
Carl
I have driven many 10s of thousands of miles over the last 7 years mostly at freeway speed and mostly on freeways pulling my GT3 on a lightweight aluminum trailer (about 4700# total) and I rarely ever used manual mode to do so. The only exception is to pull it into or hold in 5th when faced with a long uphill.
Pepper Bartender
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Guess now the gearbox software is on strike or in grandmother mode
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
