Brake dust problem solved?
Are you sticking with the HPS? Have you heard anything else about the Hawk Ceramics? I have bought everthing aside from the pads. I bought a set of drilled Zimmermans just because I like the looks. Now I am just studying the DIY's in prep for when all the parts come in.
The V8 Porschephile
This post has nothing to do with brake rotor material or type/heat/milspec numbers, etc...
It has more to do with preventing brake dust and dirt from depositing onto your wheels.
As an answer to the original poster, I've started to use this new wheel coating made by Armor All. Before you start saying something about Armor All tire protectant and how bad it really is, hear me out on this one.
I haven't used Armor All products on any of my cars for the last ten years however when I saw this new product being advertised, I just had to try it out on my Cayenne since the brake dust issue really is terrible.
The results speak for themselves and the coating lasts several weeks before another application is required.
Here's the link and a video demonstrating how it works. The honey application really sold me:
http://www.armorall.com/products/vie...gory_index=new
That video is impressive! I just added the "drilled Zimmerman rotors" statement as an afterfact. I understand that it is the pads, I just don't want to sacrifice stock feel. If either the Hawk HPS or the Hawk Ceramics performed less then the OEM Pagids then I would stick with OEM and try the ArmorAll or similiar.
I of course would like prevent the dust in the first place and use a pad that produces less dust or "visable" dust vs stock. I would like to keep the original "bite" that my brakes had before the pads wore out.
Moderator !x4
yeh right. For a while I used the stuff they coat the exhausts of SH60's and it only works so far when cleaning, the HPS stop the problem before it starts and yes same again no question
I am not too happy with Hawk HPS pads on my Touareg (same brakes as the CTT). They don't have the bite that the stock pads had and it takes a lot of pedal pressure to effect a stop from high speeds. My wife is afraid to drive it now as she thinks it won't stop. I like using HPSs on my 993 for street purposes. Granted, the V10 Touareg clocks in at over 5800 lbs I still expected more from the HPS pads. They are much cleaner than the stock pads.
I just bought the armourall wheel spay today. I gave it two coats on freshly cleaned wheels. We will see. I like the feel on the OEM pads ... I just dont like the brake dust.
Unfortunately none to be found at two Autozone's in our area though
I bought it at target. Just happen to walk by the car section and saw it. SO far it has been a week with no dust. Went on road trip with the family this weekend, rained most of the time, still no dust.
The V8 Porschephile
One trick I found was to apply tire dressing before applying the wheel protectant. This prevents the white residue from sticking onto the tire itself and running down to the bottom of the rim.
Does running it through a car wash reduce it's effects?
I am waiting for someone to tell us where we can get an aftermarket pad that feels like the OEM pads and won't dust the wheels. I don't mind a little brake dust, that's normal. What I'm seeing on my '13 diesel (fronts only) is excessive.
Moderator !x4
The fronts are always worse but both are a pain
I ran for 105k on Hawk HPS dustless without any loss of feel ( to me) others have had other opinions but I don't track it, it's my daily drive and had no issues and no dust (heaven)
There are other treatments out there to slow down the build up and make them easier to clean, 1 developed for SH60 exhausts which work quite well but only quite.
