Tranny problem- did it happen to you?
Old 05-07-2007, 11:35 PM
BobbySpeed
BobbySpeed's Avatar
Default Tranny problem- did it happen to you?
Was driving on the highway with PSM off, put the pedal to the medal to get by the slow-poke messing up the flow of traffic in the left lane, tranny down shifted to 4th smoothly, and then when it was revving high and tried to up-shift it slipped/stuttered and I had to hit the tiptronic on the steering wheel to make it go to 5th. What is going on???
Yes, my tranny fluid is at the level it is supposed to be, and no I did not have the floorshifter in manual (in case you were going to ask).
BobbySpeed is offline
Old 05-08-2007, 02:50 AM
STATMAN
STATMAN's Avatar
Sounds kind of like the rev limiter kicked in. Were you at red line when the slipping/stuttering occured?
STATMAN is offline
Old 05-08-2007, 09:08 AM
99firehawk
99firehawk's Avatar
how do you know the tranny fluid is at the proper level?
99firehawk is offline
Old 05-08-2007, 10:41 AM
BobbySpeed
BobbySpeed's Avatar
Yes it revved to the red line, but it was in automatic, not manual.
I know because I checked it as soon as I got home.
Old 05-08-2007, 12:32 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Uh oh.....
ltc is offline
Old 05-08-2007, 01:31 PM
99firehawk
99firehawk's Avatar
how did you check it?
Old 05-08-2007, 03:20 PM
mudman2
Moderator !x4
mudman2's Avatar
Agree sounds like that issue
by the way thanks for the crappy weather Brad
mudman2 is offline
Old 05-08-2007, 04:04 PM
99firehawk
99firehawk's Avatar
what weather? sunny and 85 here
Old 05-10-2007, 12:10 AM
99firehawk
99firehawk's Avatar
so bobby speed please out line the procedure you used to check th efluid
Old 05-10-2007, 07:27 AM
yetis
yetis's Avatar
yetis is offline
Old 05-10-2007, 05:20 PM
Shamus
Shamus's Avatar
Shamus is offline
Old 05-10-2007, 05:51 PM
jcr22042
jcr22042's Avatar
When PSM is switched off, your tranny goes into a different mode (sportier) with later upshifts. In addition, it will not upshift when you hit redline like it normally does. It will just bounce off the rev-limiter. This sounds like what happened in your case.
jcr22042 is offline
Old 05-10-2007, 08:40 PM
henna gaijin
henna gaijin's Avatar
henna gaijin is offline
Old 05-11-2007, 12:05 PM
99firehawk
99firehawk's Avatar
so i take it that bobby speed realized that he didnt check the trans fluid
Old 05-11-2007, 01:19 PM
phaedrus242
phaedrus242's Avatar
Get 'em Brad!
phaedrus242 is offline
Quick Reply: Tranny problem- did it happen to you?
