HItch mounted motorcycle carrier?
Official Wednesday AM Red Bull F1 test driver
Thinking of using a hitch mounted motorcycle carrier to carry my son's 600cc sport bike, total weight under 400lbs with the carrier weighing less than 90lbs. That would be a "tongue" weight of under 500 total. That shouldn't be a problem as it is well under the allowed tongue weight should it? Seems silly to carry his bike in our enclosed car carrier and haul that when not really necessary. Anyone with experience with these carriers?? (BTW, hauled the spec Miata to Road AMerica last weekend in the ATC trailer- other than really lousy mileage it did great- over 800 mile round trip.)
Super Moderator
Needs More Cowbell
Needs More Cowbell
I can't see any issues (tongue weight, aero, visibility). I've seen these used on pickups (F series HD) quite often.
You will of course have to readjust to driving without the "!" light on the dash however.
analyst
If the CS has parking sensors, then those would not be disabled, unless trailer lights are plugged into the connector. So, the rear parking sensors may not be happy.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Usually for these hitch mounted carriers, they have a plug for the trailer harness for lights that are attached to the carrier since the motorcycle usually covers these lights. If you did have the proximety sensors, they would be de-activated in the rear once the harness was plugged in.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Lewis, if I ever need a good laugh all I need to do is look for one of your responses!! Keep it up, and don't ever sell your Cayenne or 911- we need you around here...
Super Moderator
Needs More Cowbell
Needs More Cowbell
Buy another Porsche? Of course There is a very nice 75 914 (I know, 75 wasn't the best year) in the PCA Mart and a nice 968 cab would be fun (I've never owned a cab or a targa). There is an unclaimed black Carrera GT at the local dealer who they say has my name on it (a polite "no thank you", not after owning a Cayenne thank you very much)
Sell the Cayenne? Can't say anything.
Super Moderator
Needs More Cowbell
Needs More Cowbell
BTW, there is that ! again...
Pull the trailer long and often enough and I'm sure the "!" bulb will burn out. (I'm towing the trailer 3x/week for my son's karting, but as of yet, I have been unsuccessful in killing the "!" bulb.)
There problem solved, compliments of PAG and brought to you by PCNA.
If you have steel springs, expect a nose-up attitude and perhaps not the best handling. If you have PASM on the S, no problem. Keep in mind that tongue weight rating can be effected by cargo load. I don't have any documentation from Porsche, but putting 500lb of biking stuff in the back could be an issue with a 500lb pendulum off the hitch.
Overall, towing a small motorcycle enclosed trailer is really tedious. You'll get a ticket at 65 mph while the traffic is flowing at 75. You can't use the commute but you probably have two people in the car. You can't park. You'll even pay for axles on toll ways ... groan. And getting into the rear of the SUV is a pain. For just two people, it's okay, but with passengers, it gets old.
I've had a bike on a hitch loader and it's no problem, but look at cinching the bike down to the body on each side so it doesn't wobble and twist which is not good on the nerves.
Personally, given the relatively trivial cost of a carrier vs a trailer, I'd try it out and if it's really horrible, you'll know the trailer is the only option.
You can turn off the parking sensors but you have to do it every time you start the car. Still this may be less trouble than plugging something into the dreaded trailer hitch connector (right Lewis?). To turn off the parking sensors you push a button on the roof panel. I do it whenever I have a bike rack on the hitch. It's in the manual.
Super Moderator
Needs More Cowbell
Needs More Cowbell
