adding coolant
adding coolant
Started my CS on Saturday only to get a 'Check Coolant' warning. It ended up being over a half a gallon low. As a word of warning, be careful unscrewing the cap, the metal clips that the plastic cover attach to sliced me up nicely.
Anyone else have an issue with coolant usage? I figure if it happens again, it's time for the dealer to look at it.
I have seen a handfull of CS that needed to have a considerable amount of cooant added (more than 2 qts.). Having found no leaks while pressure testing the cooling system or seeing any evidense of leakage, they were topped off and sent home.
I cannot tell you why this is happening as we have not had a single Canyenne engine mechanical problem or failure since the release of the model. We sell a lot of Porsche's (60%+ of the DC market) and see them for service as well.
Next trip to your dealer I would mention the coolant issue and have them look for a leak. Atleast that way you have a service history for the issue.
I got the check coolant sign last weekend. Turned out I was down quite a bit. Added 1/2 gallon of prediluted (50:50) Prestone. I was quite surprised to get this warning because I had taken the vehicle in for the first oil change/service interval at 18.7K and I am at 20.3K. On my itemized bill for the 20K service their is nothing about coolant level being checked just washer solution. I don't know why checking coolant isn't part of the service but it should be IMHO. Antifreeze is pretty darn cheap.
I would HIGHLY recommend to check your coolant if you have more than 10k on your Pepper. You might be surprised!
Originally Posted by DrJupeman
Wow, this is scary. Coolant should be a closed system. I can't think of an acceptable reason why you'd lose coolant. Is there one?
Moderator !x4
Apart from these posts I had not heard of any other reports of this.....until this morning. I went around a corner rather quickly (:-)) and it came on. Its to hot to check right now, I will later and report.
See all the troubleshooting we are doing on this new engine for Porsche before they stuff it into that new Panaronma (or how ever you spell it).
Build the Cayenne with a new V8 and some luxury items, get all the bugs worked out, move into 100k plus M5 killer...
Got to love both the quality control of the manufacturer and the diagnostic ability of their dealers.
