Bad transfer case?
Bad transfer case?
Have to say this is not the first post I was expecting to make but here we are.
I recently picked up a 2008 S. Car was a rescue of sorts but only had one previous owner and was overall very clean and reasonably maintained. 148k miles. I rolled the dice with a shade tree “inspection” out of convenience.
Under load, I’m getting a “clicking” sound from the front axle at anything more than a very gentle throttle. It sounds and feels to be coming from the passenger side more so than the driver side. It can happen at all speeds. Is far more pronounced during low speed acceleration. Passing on the freeway is present but less pronounced. During low speed turns the sound seems to happen a little more.
I initially suspected a CV which the shade tree agreed with. I had in to a well respected a local euro shop (Garagisti in Houston) to address the “CV” and a couple other things. They have diagnosed a bad transfer case. They state the main chain is skipping under load. In hindsight the sound checks out. This repair shop mostly uses OEM parts. A factory transfer case lists for $5300 + labor. Ouch. I phoned a friend who can get the OEM at his cost which is $3500. Better, but…
Im going to get a second and probably third opinion considering the expense.
I searched quite a bit and didn’t see this issue elsewhere. I also didn’t see this as a remotely common issue while researching before purchase. Obviously didn’t expect a bad transfer case on a 957.
Should I trust the diagnosis? New OEM part worthwhile or roll the dice on a used unit, considering the costs? Any worthwhile potential alternative fixes? Anyone else been experience something similar?
Sorry to hear the new to you Cayenne is having issues. I recall when I replaced my transfer case solenoid (and controller), it resolved a slight binding when turning at slow speeds like in a parking lot or making a u-turn. Don't recall any clicking, that sounds more like a CV axle.
After replacing the TC solenoid, the Cayenne also felt a little smoother while on the highway so you may want to investigate a little further before you start throwing parts at it. There's a few threads on here about transfer cases so dig in!
545moose (05-24-2024)
I’ve had noises while turning. Changing the front diff fluid resolved it. Might try that?
how did they diagnose the chain skipping?
this is not scientific, but I don’t think that’s a common failure on these things?
From the shop:
Finding:
found loud popping noise from vehicle under acceleration, continued testing and inspected front carrier and driveshaft with no issues found, lifted vehicle and verified noise only present under load with weight of vehicle on ground. Found transfer case chain is skipping and making loud noises, replace transfer case and retest.
Premium Dealer
the front differential is often the problem, we had to replace on on a 2006 we had here after trying everything, drain the fluid and see if there is bearing material in it
Posts were from a year ago and never given feedback or resolvement, bad form. Clicking sounds like the front Diff which do go bad, especially when the fluid isn't changed regularly. The Transfer cases can be rebuilt, you can find Bearings, Gaskets, Clutches, and the Chains. Chains aren't cheap, just over $200 alone. The Transfer case is a Borg Warner design and in common with earlier Touaregs and Q7's. Transfer case only holds about 1qt of fluid (ATF). If you want it to last you should change the fluid regularly, it's a cheap an easy fluid swap. Transfer case ATF spec is Esso ATF LT 71141 whereas the Transmission ATF is JWS3309. Many of the higher quality Synthetic ATF's meet both specs but if you are using an older fluid make sure it meets the proper specification. I use Redline D4 in both as it is a Group 5 synthetic which meets both specifications.
The following 2 users liked this post by hahnmgh63:
545moose (05-24-2024),
ekstroemtj (06-25-2024)
Rebuild it!!!
A rebuilt 955/957 TC is about $900. VERY few parts. I have used double clutch fluid in my 957 GTS TC for years now with no issues what ever. Do not buy a new one. Too many good rebuilt units available
Unibtanium (06-24-2024)
