Starting Issue
My '09 Cayenne S started failing on the first start each day, but would start great after that. Battery was going south; replaced it with a new AGM battery.
It cranks strongly on the first failed attempt? That would rule out the starter. I had a weak starter that cranked, well, weakly on the first try then would crank strongly on the second try.
If it does crank strongly I would think it's the check valves in the in-tank fuel pumps and it needs to build fuel pressure to start. Oh, and this is the DFI version so there could be something with the HPFP.
