Location of F/R Auto Leveling Headlight Sensors - 2009 Cayenne 957 Turbo S with PDCC
Car is a 2009 Cayenne 957 Turbo S with PDCC.
On my recently put back together widebody Cayenne, the headlights go through their start up routine - dip down and then raise up, but because of the aftermarket front bumper I can't adjust the headlight brackets / buckets manually any further down and the headlights are pointed up too high, so I'm looking to adjust the arm length for either the front or rear leveling sensor to fake the controller into lowering the lights further to make them "level". I did a similar process on my 997 when installing a racing suspension and just made a new bracket for where the rear leveling sensor attaches to the Lower Control Arm, but on the Cayenne, I can't find the sensors, even after referencing the PET catalog and the diagrams. I thought I found them, but they turned out the be the air suspension leveling sensors as there's one in that position at all 4 corners. In PET, looking at where they should be, what I see is components of the PDCC system in the rear subframe, so I'm either:
- looking in the wrong place,
- or because my Cayenne has PDCC, the Xenon light leveling sensors are located somewhere else,
- or they're actually tied into the suspension leveling sensors, in which case I'm SOL and am going to have to come up with a different plan,
I believe the Cayenne is a little different from the 997 and uses the same sensor for suspension and headlight calibration.
Search for this part number and you will find all kinds of diagrams:
95534107621
It is located on the upper control arm. You can see find it on page 158 here - part #19:
https://www.porsche.com/all/media/pd...SA_KATALOG.pdf
95534107621
That's what I was afraid of after removing one of the sensor arms, having the rear drop down to the end of the travel, and not seeing any other similar looking height sensors. This means I will either need to manually lift the rear of the headlight buckets or I may need to recalibrate the suspension to lift the rear of the truck a little, as it looks a little low to me anyway, relative to the front, but my level placed at a few different locations says I do have rear to front forward rake, even though it doesn't often look like it - probably because of the sloped roofline at the rear. I'll have to look at some online photos as to how others are sitting.
Thanks for the info and confirming my suspicion that the light level sensors and suspension level sensors are one in the same.
I do not recall what Durametric can do for 957 function for this issue, but you might be able to shim top or bottom of travel. Swinging for the fences here.
Received 1,141 Likes
On the 958 lights - there apparently is a calibration that can be done with a Porsche specific code tool (I think iCarScan was where I saw it.. don't know on Durametric, I'm sure PIWIS has it if iCarScan does) Don't know if that's true on the 957. Since the level of the vehicle and the aiming of the lights is intimately tied together - the thing to do is to first get the vehicle set to where you want it to be, then look into the headlight adjustment. If that's doable to me it's much preferable to shimming things.
If where I have it isn't good enough, I'll have to either lift the rear a little with Durametric settings since i think it might be a little low anyway or I'll need to trim away a bit of the bumper fiberglass that's hidden under the headlight after they're installed that would let me lower the front if the headlight bucket on that one side using the front adjusters.
When the lights first come on, they're actually not aimed too badly, then a few seconds later the leveling sensor kicks in and lifts them up - it would be better if they just stayed down where they are when the switch is first turned on.
I'm inclined to leave it as I have it currently and see how it goes.
