What Did You Do To (or With) Your Cayenne Today ?
Old 08-11-2024 | 03:31 PM
  #1276
VoilaGT3's Avatar
VoilaGT3
Default USB-C socket custom install in center console
Continuing the armrest rejuvenation tooling in a USB power outlet into the lower rear console. Pretty self explanatory.
Old 08-13-2024 | 02:51 AM
  #1277
TRINITONY's Avatar
TRINITONY
Changed my rear brake rotors, pads, , line and bled brakes.
thesteve (08-16-2024)
Old 08-16-2024 | 10:26 PM
  #1278
thesteve's Avatar
thesteve
Fixed my side marker light!
Got the bulbs and then thought my inadeptness was the cause of one of the wires breaking off.
Turns out the old bulb was still good and one of the wires just became embrittled and opened up.
Found these pigtails on eBay for $10 per pair:
"Universal Pigtail Wire Female Socket W5W Harness Side Marker Light Plug"
Took a lot of cross-referencing... I think the key search connection was VW Passats.
Anyway, it fits snug and I finally got with the times and used the butt connectors with the waterproof heat shrink, instead of the free ones from work that gave me carpal tunnel.
Also got to try out my new butane soldering iron / micro-torch from Harbor Freight.
Worked like a charm.
VoilaGT3 (08-18-2024)
Old 08-17-2024 | 12:31 AM
  #1279
KGeorge's Avatar
KGeorge
Wrapped up a month in BC with a 16 hour drive back to Utah.
The following 7 users liked this post by KGeorge:
frederickcook87 (08-19-2024), golock911 (08-17-2024), gsxrdoug (09-02-2024), thesteve (08-17-2024), TomF (08-18-2024), tomhartzell (08-17-2024), TRINITONY (08-18-2024) and 2 others liked this post. (Show less...)
Old 08-18-2024 | 12:29 PM
  #1280
Rossi's Avatar
Rossi
Originally Posted by frederickcook87
I checked their website a couple days ago and nothing there… might email them again soon
Any word, any hope:-)
Old 08-18-2024 | 11:24 PM
  #1281
TRINITONY's Avatar
TRINITONY
Drove from MD to LI, New York this weekend, total of 650 miles were put on. The CTTS performed flawlessly at legal speeds. Got to the belt pkway around 11 pm with no stand still traffic but heavy volume with EVERYONE believing they were on some racetrack...lol....for that last hour of the ride it was one hand on horn, full attention mode and head on a swivel. NY drivers r a special bunch...lol... Saw tons or pcars over the two days but not one 957 CTTS or any 957 variant, lots of high end BMWs, Audis, etc.. all running in the high rpm range.
Old 08-18-2024 | 11:31 PM
  #1282
VoilaGT3's Avatar
VoilaGT3
Sounds fun, until the horn part.
Old 08-19-2024 | 08:39 PM
  #1283
frederickcook87's Avatar
frederickcook87
nope, none 😟
Old 08-19-2024 | 10:14 PM
  #1284
TRINITONY's Avatar
TRINITONY
When everyone is driving like this at night, yah need ya horn..
VoilaGT3 (08-19-2024)
Old 08-19-2024 | 11:10 PM
  #1285
VoilaGT3's Avatar
VoilaGT3
Looks like KC... lots of VIPs rolling slow in their personal left lane.
TRINITONY (08-20-2024)
Old 08-20-2024 | 11:33 AM
  #1286
golock911's Avatar
golock911
I thought I had successful taught everyone how to back into the parking spot, then realized the Tesla charging port is on the rear corner...
Old 08-20-2024 | 07:41 PM
  #1287
VoilaGT3's Avatar
VoilaGT3
lol, I bet they were thinking you were trying to be like them...
Old 08-26-2024 | 02:00 PM
  #1288
Richard Flores's Avatar
Richard Flores
So done quite a few things on my 08 GTS. 138k miles on it now.
2022
  • Feb- replace the roof liner that was sagging.
  • engine motor mounts
2023
  • Feb 2023 Changed out the front suspension (Upper control arms, lower control arms, tie rods etc...mevotech supreme)
  • Feb 2023 Rebuilt/refresh the front air suspension and top mounts
June 2004
  • Changed the headlight with the new Matrix LED aftermarket headlights
Aug 2024- maintenance items
  • Spark Plugs
  • Serpentine belts
  • Water pump
  • Thermostat
  • Expansion tank
  • Starter
  • AOS
  • Purge Valve
  • Vacuum Pump
  • Battery (H9)
  • clean intake valves
  • recharge the AC system
  • Clean drain plugs
  • Changed oil (liquid molygen)
  • Changed side light bulbs
  • Put Xtrons stereo unit in for carplay/AA
Libast (08-26-2024)
Old 08-26-2024 | 04:12 PM
  #1289
VoilaGT3's Avatar
VoilaGT3
2022
2023
June 2004
  • Spark Plugs
  • Serpentine belts
  • Water pump
  • Thermostat
  • Expansion tank
  • Starter
  • AOS
  • Purge Valve
  • Vacuum Pump
  • Battery (H9)
  • Clean drain plugs
Where did you find the AOS? Is it an OEM?
Old 08-26-2024 | 05:49 PM
  #1290
Rossi's Avatar
Rossi
@Richard Flores How do you like the LED headlights?
Quick Reply: What Did You Do To (or With) Your Cayenne Today ?
