Lifter Issues
Here is what I've checked to determine the culprit was lifter issue:
1- Checked headers and verified torque no exhaust leaks.
2- Checked Spark-plugs and verified torque.
3- Change oil and added additive SeaFoam
4- Raised Boxster and checked the noise with a short hose and also with a screw driver to the ear. The noise is loud old sewing machine (awful noise)
I have to ask if this is an issue that is on the rise or just my luck...
The repair cost to replace all lifters plus labor is $1,850.00
O'well happy motoring!
We know in cases of even extraordinary high miles lifters can last without any issues as can all the other engine parts.
Many owners drive their cars completely unaware of the fact there are any lifters in the engine at all and never have any problems. Maybe they can't hear the lifter noise over the failing IMSB..
Just kidding.
About all I can offer is the advise to change the oil/filter at frequent (reasonably frequent) intervals. That is about all you can do for the lifters and the rest of the engine. Oh, that and treat the engine (the entire car) with some reasonable amount of automotive mechanical empathy.
As for Seafoam… let us see what this contains that could possible for it to supply extra or additional engine protection…
The major component is "pale oil" CAS # 64742-54-7 which makes up of between 40 and 60% by weight of Seafoam.
What is 64742-54-7? It a complex combination of hydrocarbons obtained by treating a petroleum fraction with hydrogen in the presence of a catalyst. It consists of hydrocarbons having carbon numbers predominantly in the range of C20 through C50 and produces a finished oil of at least 100 SUS at 100.degree.F (19cSt at 40.degree.C). It contains a relatively large proportion of saturated hydrocarbons.
Pretty much the same base oil as is used in the manufacture of a number of oils.
Next comes "naphtha", CAS # 64742-49-0; and this makes up between 25 and 35 % of Seafoam. This is a feedstock for high octane gasoline and can be turned into a fuel for camp stoves, lighter fluid and a cleaner.
Third on the list: IPA. CAS # 67-63-0. Seafoam contains 10 to 20% of this stuff. What is this stuff? Isopropyl alcohol. This is widely as a solvent and as a cleaning fluid, especially for dissolving oils.
Dissolving oils? Not what I think I'd want to use in my Porsche engine's oil.
I see nothing in Seafoam that offers any "additional" lubrication. It simply replaces the existing oil (hopefully an approved oil) with some pale oil and a couple of other items: camp stove fuel and a cleaning solvent.
Yuck.
Mike
Because of this oil flushes and special oils just do not work with these lifters. In fact, in our experiences most of the time the issues are compounded with flushes as debris throughout the engine is broken free and suspended in the oil, then fed to even more lifters, causing even more issues.
The lifters have not been updated, they are the same lifters found in Cayenne engines and many other BMW and Mercedes engines dating back to the early- mid 90s. The lifters themselves are not problematic and never give issues in other applications that use them. Why? Because the factory M96 oil filtration and bypass system allows too much debris to bypass the filter and end up suspended in the oil.
Though the part suffix may deviate, trust that the lifters weight the same, have the same internal characteristics and the same crown dimensions as those dating back to 1997.
Also, ensure that you do not have a failing cylinder/ piston before going further. Thus far this year we've seen two dozen misdiagnosed "lifter issues" that turned out to be a failing cylinder. They make EXACTLY the same noise and at the same rhythm as a noisy lifter and behave just like them. This is fooling shops and dealers all over the country. Here when we hear a "bad lifter" we first assume that a cylinder is failing and then quantify that it is not before moving on to performing lifter intervention. Sometimes it takes a day of poking around and diagnosing to conclusively determine exactly what the noise is.
http://jenniskens.livedsl.nl/Technic...0ivt_de_gb.pdf
What killed the cam was the excessive lash that was created by the lifter failure. Common and typical.
If you need core components email jud@rabyenginedevelopment.com
