Option Codes 222, 224, 231, 582..????
Help!
I just bought a 97 Boxster and can't find out what it's options were.
Any ideas what codes 222, 224, 231, 582 mean?
TIA, Rainer
TIA, Rainer
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Some of the option codes are internal codes. For example, there's a code for US emissions. All US cars have it, but you won't find it in any order guides. They put the code there so the factory knows what to build.
Here are two good places to investigate options:
Porsche Option Decoder
Boxster Options Matrix
Yoseif
Yoseif
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
THXS - I figured that somehow those are likely to be connected w/ LSD, since 220 / 221 normally is LSD at the older models.
Originally posted by David Rettew:
<STRONG>222 & 224 are the traction control system and automatic limited slip systems.</STRONG>
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Yoseif,
thxs. most code those sites worked for, but I already tried the remaining ones I mentioned - doesn't work.
I believe that those codes are somehow connected w/ the Pxx Package Options....
Originally posted by yoseif:
<STRONG>Some of the option codes are internal codes. For example, there's a code for US emissions. All US cars have it, but you won't find it in any order guides. They put the code there so the factory knows what to build.
Yoseif</STRONG>
Yoseif</STRONG>
Keeper of the Truth
Originally posted by pho:
<STRONG>where do you find the codes on the car?</STRONG>
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
So the old 231 pops up again. This has appeared on 993s as well. We have never been able to find out what 231 is. Looks like we may never know,
Ciao,
Adrian
911C4
Ciao,
Adrian
911C4
I am looking at a 2000 boxster that has the 222 and 224 options on it. Traction controll and Limited Slip diff. Is any of this related to PSM or the TC button on the dash. Also, is this a real LSD, or is just the electronic part of PSM.
Yoseif
Yoseif
