Autocross numbers for non-magnetic doors
All,
What have you found to be the best SCCA compliant (i.e. 8" tall) numbers for autcrossing on cars like the 718 Cayman that have non-magnetic doors?
I've been using reusable vinyl numbers, but the adhesives seem to gets dirty easily, particularly when being removed and replace between drivers.
I'm not really interested in a permanent solution - My co-driver and I need to be able to change them between runs. And I'd prefer not to drive around after the event with my numbers on.
Maybe the reusable vinyl is the best solution, but I thought I'd ping the forum to see if other solutions have worked.
For example, I could put some magnetic chalkboard contact paper on the doors for the weekend, and use magnetic numbers that are easily switched. Not sure if that will work at speed though.
Thanks!
John
Thanks!
John
All,
Thanks!
John
Thanks!
John
-I think one big panel is easiest to handle and keep clean, but this may depend upon the curvature of the door
-I tape the leading edge with electrical tape so it doesn't get as dirty underneath
-When the underedge does get dirty you can clean it with glass cleaner and a paper towel and get most of the grit off. Some of the adhesive will be left.
I haven't found anything better than reusable vinyl.
The glass cleaner and electrical tape are good tips.
I will try the glass cleaner tonight, and the electrical tape this weekend.
Cheers!
John
I can't speak for everywhere, but if you put giant easily visible vinyl numbers on your window in my SCCA region like KPL posted, we'd probably not give you too much crap about it, and maybe not say anything at all, depending on who's tech inspecting that event. It may not meet the letter of the rules, but certainly meets the spirit/intent and lets us identify your car. We have a lot that try similar but in a way that's extremely hard to read; certainly not with giant easily visible numbers.
Often on course there's other background stuff coming through windows that make numbers much harder to read at-speed than they are when you're standing beside your car. Shoe polish numbers are about useless.
I've had a lot more success keeping individual vinyl adhesive numbers and letters clean and reusable than one large panel.
It was so hard to apply the large panel without bubbles and then to store them back on the large cookie sheet without getting dirty. Also the larger panel leading edge I had to tape down as suggested above but individual numbers and letters I haven't needed tape.
Finally as I worked a course yesterday, it was really hard to read numbers in the window, less hard but still effort needed to read numbers on the rear quarter panel, and easy to read numbers with good contrast on the door. Im also relatively young with good eyes.
So please from a corner worker perspective put big contrast numbers on the door
If you have a pop rivet gun, you can do what I did. Grab an old piece of corrugated roofing and rivet it onto the sides of your car. The magnetic numbers not only stick well to the steel roofing, but it helps cover up some of that horrible Miami Drug Dealer Blue paint.
The following 5 users liked this post by Mozella55:
IPA1 (08-13-2023),
Lincoln Peters (04-30-2021),
paddlefoot64 (10-22-2020),
RacingChris44 (02-27-2023),
Robert Nixon (11-13-2020)
We used static cling vinyl that we installed with a spray bottle and squeegee. No adhesive and the same set lasted for years even after taking them on and off numerous times.
