How to disable TPMS warning?
Do you want to disable the message or the whole system?
If you just want the light to go away temporarily you can reset it using a durametric but it will come back after ~ 15 minutes of highway speed driving.
A shop wont do this for you and i have not had to on my 911 but my Audi R8's TMPS warning was a constant issue regardless of what my actual readouts were. I eventually had the sensors removed and created a loop in the wiring leading back to the main main control unit then hard programmed what the input value was. Not as hard as is sounds
Could leave you driving on under / over inflated tires but in my opinion with modern low profile tires if you cant tell by feel alone if your tire pressure is off you shouldn't own a performance car. Feel free to PM me if you want some instructions
My email is goochbenjamin@yahoo.co.uk
tjabk you so very much in advance
I have a 2011 tts and have never had a problem with warnings with 33 lbs front and 39 in the rears, as long as I followed the recalibration process. Even at 31 front and 36 rears it never triggered a warning.
