GMG or H&R springs
#46
I did springs first. They settled the car a fair bit, but with the stock unit it still porpoised a little on undulating surfaces in mode 1, and I found it too harsh a ride for anything but smooth surfaces in mode 2.
DSC fixed this. Mode one is a firmer, yet more compliant ride. The car no longer porpoises around, no longer feels floaty. Mode 2 is left on most of the time. Mode 3 is definitely stiffer, but is still usable every day.
#47
DSC results in the shocks actively absorbing bumps better than with the stock unit, so the ride is more settled, and less bouncy. In all honesty if I was doing it again I'd have tried the DSC first, springs second, but I like the aesthetic so would have ended up with the same result.
#49
So springs make it stiffer than stock.
DSC make it softer than stock.
So does the DSC make the ride compliant enough to negate the stiffness the springs cause?
#50
Hmmm when I talked to him last he asked me first thing if I wanted to do springs but I said no. So since I've changed my stance I have to ask him again what they recommend.
#51
Personally, I don't understand why folks buy re-branded springs anyway. Is Eibach really creating one-off springs in small batches for these companies? Wouldn't the cost for that make it ridiculous?
#54
I would not buy anything from GMG.
but
YMMMV.
I would also not buy Champion lowering springs.
(The white ones)
The previous owner did and the car is ridiculously low IMO
but
YMMMV.
(The white ones)
#55
By now, jem7v, you've probably (i) removed those winter tires from your car and (ii) had your car properly aligned--issues which you identified and explained so effectively in your "Suspension upgrades" thread (https://rennlist.com/forums/997-turb...-upgrades.html). No doubt you addressed those issues before you invested in a new exhaust system for your car. Given the expectations that you have for your car, you just may have a defective, low-mileage car: it's "super bouncy" and doesn't respond well to your driver inputs. On the other hand, maybe Porsche engineered a car which simply isn't a match for your driving skills.
There's no need to take the TT Surgeon's advice by taking the car to a track to establish a baseline for its handling. That type of analytic, rational approach isn't for you. Your driving skills and your detailed knowledge of your car's handling are more than sufficient. Moreover, you've "tried reading as much material on this as possible. But everyone contradicts each other," and the relevant input that you've received in this thread--well, oddly, it's not what you want to hear since you've already conducted your own analysis by comparing your car with a "modded turbo S."
You ask for advice, you receive it, and then you try to refute the advice that you've received based on conclusions that you've already made.
Best post i've read today / this week / this month
#60
The reason there's not much feedback on Techart is because like Champion or GMG or any of the premium brands they aren't really making their own springs, they are just re-branding either H&R or Eibach. There really are very few players in the spring game.
Our Turbo came with Champion (H&R) Springs. I think the ride height is perfect. My wife daily drives it without issue IDK what some of you guys are talking about when you say it's too low but this is all personal preference. However I will say they're just soft and squishy and really don't make the car handle any better at all. Our turbo is 99% street car though and since I like the way it sits the Champions will probably stay on there for now.
I have 3 way JRZ motorsport struts and 900 lb springs on the GT3 for when I want to go to the track and have fun.
