997 Turbo Forum 2005-2012
Opinions on a TT wheel idea
Old 05-30-2012 | 09:38 AM
  #31
speed21's Avatar
speed21
Originally Posted by 993S
Long post but not correct, I stand by what I said
I have no issue being proven wrong, you are the expert here, but if I'm wrong please let me know where. Is it the offset calculator that is incorrect?
Old 05-30-2012 | 09:50 AM
  #32
TT-911's Avatar
TT-911
I edited my post, hope it clears things up.
You can never think wheels alone, always add the tires. Think how a tire sits on a wheel, the outer edge of the tire is the issue, not the wheel.
And for the record, I am not an 'expert', I do not claim to be, simply like to talk wheels. It has been my passion from childhood.
But I am no engineer, I designed wheels and had other people to the technical work. But of course over the many years in the business I know a thing or two about it.
Old 05-30-2012 | 11:12 AM
  #33
speed21's Avatar
speed21
I am sure I am boring by now but here goes again.
You are riding a 11.5 ET44 with a 305, correct ?
If I am on a 12 ET45 with a 305 I will have less risk of rubbing than you.
Attached a GT3-RS with 12X19 ET51 (and 5mm stock spacer, so real ET46) on 305, weight of car on rear right wheel.
Still plenty of space and the tire sits so very nice on the wheel. Picture perfect.
Now I'll keep quiet
Yes, but as per the figures i produced from the offset calculator the wheel of the 12 /45 essentially sits 5mm out of the guard more than the 11.5/44. The tire and the wheel are partnered. Sure you can stretch the sidewall so the rolling diameter is reduced along with the sidewall clearance but essentially the extension of the wheel is greater using the 12 by 5mm.
Then there is the aspect of reducing the rolling diameter of the rear wheels to the front wheels once the rolling diameter of the rears are reduced due to the stretching. It is AWD don't forget and Porsche does state that replacing worn tires at one end is not desirable because the rolling diameter increases with new tires vs old tires at the other end. So isn't that creating the same scenario? Or should 9" be used in the front to counter the reduction in the rear? I know this wouldn't matter on a RWD GT3RS.
Don't think in terms of wheels only and you'll get it, stretched tires sit lower and narrower on top.
For ex. 11 et40 is worse for a turbo than 12 et45 with similar tires. The load of the wheel is devided inside and out giv 6 mm diff on the outside. On the 11 et40 the load is complete and only towards the outside , so 11 mm. What do you think is better ?
I don't understand. You would really need to explain it to me regarding the load you are referring to. If you are referring to the load being shared either side of the wheel bearing from offsets, most of these offset configurations we are talking about here are shifting between 6 and 11 mm's either side depending upon the rim if comparing against the standard OEM 11/51. So I'm assuming these measurements are within the load tolerances on the wheel bearings so vibration or premature wear does not become an issue.
OK. But the wheel and tire are essentially operating together as one unit. You'd need to elaborate so i understand the technical aspects of the point you are trying to get across. I've always had an interest in the aspect of wheel offsets and the effects they can play on a car where things are moved too far off the standard. Any advice/knowledge is appreciated.
Old 05-30-2012 | 02:21 PM
  #34
dianic's Avatar
dianic
I think I understand the point being made here, although Paul's approach is scientific to the mm, while Denis' approach is more empirical, taking into account an element which the tire calculator cannot take into account. The way the tire sits on the wheel.
I have attached my "artistic rendering" of this discussion. Denis advocates that the way the tire spreads over the 12 width wheel it reduces its height in the corners, vs the way the tire bulges on the 11 width wheel, and this makes it look better even if according to the wheel calculator it seems to sit further out.
Look at a ruler to realize the width of the 2mm that we are talking about, its not 0.2 of an inch, but of a centimeter. That is tiny! And could be explained by the way the tire spreads on the wheel, at the absolute corner of the tire...
Old 05-30-2012 | 02:22 PM
  #35
dianic's Avatar
dianic
LOL at my drawing. Gawd.
Old 05-30-2012 | 02:43 PM
  #36
phillipj's Avatar
phillipj
Thanks everyone for their input. I will 'mock up" the wheels and see if I like it.
Nick,
I like your idea about "reversing" the idea. Like you said I'm not skilled enough to Photoshop that! But I have friends that are... Maybe I'll just leave the wheels alone and use the money for my custom exhaust..
I REALLY like those D2 wheels.. They are awesome.. Pretty pricey though..
I like the BBS 's that Denis is thinking about as well.. They would look great on his new car.. I have to agree about the black wheels.. I like a polished lip as well.
Where I live every pimped BMW to Scion has black wheels..
Although Nick's car look beautiful with the black wheels. But it's a Turbo with those big red calipers.. It just "works".
Thanks again for all the input. I'm really leaning a lot for this forum..
Phillip
Old 05-30-2012 | 04:18 PM
  #37
CampioniShop's Avatar
CampioniShop
Former Vendor
Sorry but what are you talking about ? Boat anchors ? Really ? There is NO alternative to a BBS wheel at 400 euro per wheel. As I said they are light and the casting process is very good. Did you see the weight off those CH-R ? The stock wheels are forged and weight of these BBS's is similar.
Next, you are offering these BBS for 2800-2900 (dollars) and I can get them for 1600 (euro) here local, no freight, no import duties. nothing.
What would you do ??
19x8.5+51 are 24.3 lbs and 19x11+56 are 26.3 lbs. Both are very high, conservative offsets that reduce the backpad material for better weight.
The Forgestar F14s are available in 19x8.5+45 at 23lbs and 19x11+40 at 26 lbs with the same flow forming technology as BBS for 60% of the price in the US.
A well engineered forged monoblock wheel in those specs will weight 18 - 19 lbs front and 21 to 22 lbs rear.
You quote EURO prices, which have always been notoriously lower in EU than in the US. It's a case of apples to oranges here.
Old 05-30-2012 | 04:37 PM
  #38
TT-911's Avatar
TT-911
Stock Turbo Wheels
8.5x19" 23 lbs. 8 oz
11x19" 27 lbs. 14 oz.
BBS CH-R 12x19 ET 45 - 28 lbs. (12,8Kg)
BBS CH-R 11x19 ET 56 - 26 lbs. (11,9Kg)
BBS CH-R 8.5x19 ET 51 - 23.8 lbs. (10,8Kg)
BBS CH-R 9x19 ET 53 - 24.5 lbs. (11,1Kg)
Again , boat anchors ??
BTW, Forgestar offsets and rear width are wrong for me. No use for them even if they were cheaper than BBS.
Old 05-30-2012 | 05:00 PM
  #39
CampioniShop
Former Vendor
The Forgestars can be made in 19x12 as well. The usual fitment on 997 widebodies is a 19x11+40 - that offset is spot on in regards to fitment.
Old 05-30-2012 | 05:20 PM
  #40
TT-911's Avatar
TT-911
Maybe for you, for sure not for me. But going back and forth with a wheel seller is not what I like about a Porsche forum so I'll leave it at that.
I only called you out on the 'boat anchor' remark. It's wrong and you know it.
It's a shame vendors have to knock other products down if margins are not good or they can't get them.
Old 05-30-2012 | 05:25 PM
  #41
TT-911's Avatar
TT-911
Paul, when I have more time I'll try to explain it better. Not easy in a foreign language, you know. But Nick's drawing is not that far of the mark.
First I have to get this out of the way :
https://rennlist.com/forums/9572462-post44.html
Old 05-30-2012 | 10:10 PM
  #42
speed21's Avatar
speed21
Thanks but no need for drawings. I understood what Denis was saying about the pulled sidewall creating more clearance than a vertical sidewall. Just don't hit any big bumps lol. Imo 305's hardly look baggy on an 11"rim, more vertical than an opposite angle. The wheel protector bead/rim is also there on street tires whereas on R spec such as Michelin PSCups the bead is not there as seen on Denis's GT3RS photo. The protector bead can give a visual appearance the wheel is sitting out further than what it is, however pulling the the sidewall of the tire can make the street tire look more visually angled than what would be the case with an R spec tire. How do i know? Because i have a separate set of rims with R spec tires on them and the look it gives is quite different to the sidewall on my street wheels and tires. So, this needs to be taken into consideration especially if aesthetics are the main goal here....which appears to be the case i.e. lowering and using more aggressive offset wheels etc. And not saying there is any right or wrong using 12's with 305 street tires....but there is relativity where aesthetics are concerned. IMHO of course
And if lowering is the clear/main objective along with having no requirement for spacers then the 19 x 12 ET 45 will certainly do that trick.
Absolutely. When cast and forged and are concerned there are clear advantages....hard to argue that .
Ultimately at one point it all comes down to dollars and what one expects in performance terms.
BBS are obviously good quality rims or Porsche wouldn't use them as an OE supplier.....although i note Porsche has used mainly forged offerings.
Stock Turbo Wheels
Lol...but quite funny in a metaphorical sense.
And to add to the weight chart;
OEM 19 x 8.5 ET56 - 23.98lbs (10.9 Kg)
OEM 19 x 11 ET51 - 28.82lbs (13.1 Kg)
For reference purposes i weighed up my stock rims on our warehouse digital scales. The scales are accurate.
So where the CHR's (8.5 and 12'S) are concerned there is no weight penalty (or advantage) over and above the stock forged oem rims. Maybe a slight penalty on the fronts.
Old 05-31-2012 | 09:17 AM
  #43
amerlemans's Avatar
amerlemans
What timing that I find this thread they day my silver BBS Ch-R's were delivered. I went with the 8.5 up front and 11.0 in rear. My car is GT Silver like Speed21's and I just don't know whether the color is going to look right. I am going to do a test fit today to get some other opinions to see if the color of the wheel is too close to the color of the car. While I love the color, I find the machined finish (as the stock wheels are done in) to look best against the GT Silver. If I determine that these CH-R's color is satisfactory with the car color I will have the tires installed (305 rears) and post additional pictures.
As far as being boat achors -- that is a ridiculous comment to make. I had Forgestar F14's on my 997S and they are great wheels as well. Not going to knock them.
Another thing to keep in mind is that the 11" rears are 2lbs lighter than the 12" rears.
As far as price goes -- I got mine from Tire Rack for $2,750 delivered..... to my door (in 3 days).
Old 05-31-2012 | 11:46 AM
  #44
TT-911's Avatar
TT-911
Good choice !!
Yeah, that 'boat anchor' comment made me all defensive. What a comment to make from a 'pro'
Anyway, the 11 in the back will need a spacer.(5 mm is fine) Otherwise they'll sit to deep inside the wheel well.
Price you got seems good. I am paying for mine 1600 euro (8.5 and 12) which comes to around $2000. I have to get them myself but the vendor is close enough.
Just ordered them btw, picking them up next Wednesday.
Old 05-31-2012 | 02:58 PM
  #45
dianic's Avatar
dianic
Lots of pics Denis. And mask those calipers with red tape so it will look like my car! Ha...
Quick Reply: Opinions on a TT wheel idea
