997 Turbo Forum 2005-2012
Xona Turbo XR1000 Conversion (ByDesign)- Full Review!
Old 05-21-2020, 06:57 PM
wcarson
wcarson's Avatar
Default Xona Turbo XR1000 Conversion (ByDesign)- Full Review!
Hi Guys,
I own a 2007 997.1TT, manual 6 speed. I've had the car for a couple of years now, and it is my semi-daily driver. Over the last couple of years, the car has undergone several iterations of changes and modifications. I got the car with a decent set of GMG modifications, all done by GMG in-house in Santa Ana. When I bought the car, it had stock 3.6L internals with 63mm VTG's, GMG intercoolers, full GMG headers and exhaust (with cats), and a custom GIAC tune. It has the DSC suspension module, as well as GMG sway bars, lowering springs, etc. To make a long story short, soon after I bought the car, I had GMG do a full rebuild on the engine. We did a 3.8L conversion with Carillo rods, EVOMS headstuds, GT3 oil pump, and a few other things. I also had the VTG turbos upgraded to 68mm. I worked extensively with EVOMS on a custom tune and was running 91 pump mixed with e98 to make a blend of e20 or so. The motor ran beautifully. My 60-100 times were 3.1-3.2 seconds. 60-130 times were generally around 7.4 seconds- my fastest was 7.25 seconds. These were single 4th gear pulls with no shifts.
After around 5,000 miles and 18 months of seat time with the built 3.8L and the ethanol blend, I was getting a bit tired of always toting VP racing e98 around to mix in whenever I filled up with 91 pump. And like everyone who's reading this, I wanted more. More power, more torque, and more immersion while driving. I do not track the car (I have a dedicated track car). I wanted this car to be a reliable street fighter and daily driver. I love driving, and I view my car as my mental and physical sanctuary and therapy. After doing quite a bit of research and extensively communicating with Sam Ahdoot at ByDesign, I finally decided to take the final plunge and get rid of the VTG's and go for the conventional turbo swap, in this case, we decided on the latest version of the venerable XonaXR980- now called the XR1000.
My concerns about jumping from VTG's to the Xonas were many......would the lag be really bad, how would the daily drivability be with speed density tuning, would the EBC be a big hassle, etc. I discussed these issues extensively with Sam and he was very open and honest with me and also very reassuring. For those of you who have not interacted with Sam Ahdoot at ByDesign- I can tell you that his legendary reputation is 1000% well-earned and extremely well-deserved. He is simply awesome for lack of a better word!!!!! I am only a few hours away from the Los Angeles area, so it was the natural choice to drive the car down to him, and have him and his team of craftsmen and tuning wizards actually do the entire conversion and tuning on site and in house.
So here's what we did:
-Xona XR1000 with Tial WG's
-Tial Q50 BOV's
-HKS EVC
-IPD Plenum, Y-pipe (the big ones) GT3 TB
-Prometh methanol injection
-ID1300 injectors
-Protomotive twin disc conversion using sachs 487pp and GT3RS LWFW
-Full custom Tuning by Sam- including full Dyno and street tuning
-Tunes for 91 pump, 91 +meth, e85
-Retained my existing GMG headers, full exhaust, 200 cell sport cats, AMS Intercoolers
So here are the end results!!!! All dyno pulls were done at World Motorsports on their state of the art Mustang awd Dyno. This included the initial baseline dyno with my 68mm VTG set up- I had them dyno it with my 68mm VTG set up before they did anything.
-Baseline dyno 68mm VTG: 601 wheel HP/ 610ft-lbs
-XR1000 91 pump: 687 HP/654 ft-lbs
-XR1000 91 + meth: 800hp/776ft-lbs!!!!!! I rounded to 800 wheel HP. It was hot in the dyno room and the actual number was 799.567!!! This tune was a bit aggressive so Sam dialed it back a bit so as to not lean on Meth so much. See next line.
-XR1000 91 + meth FINAL street tune: 750hp/750 ft-lbs. This is my daily driver tune. 750 wheel HP. That should get me from A to B.
-XR1000 e85: 850 HP/809 ft-lbs. HOLY ****.
Driving Impressions: Holy crap this is car fast!!!!!!!!!!! I picked up the car last week and drove it home. I briefly drove the car on a lower boost setting (22 lbs) on e85 when I first picked the car up. I briefly got on boost a couple of times, and I knew the car was a beast when I hit a small irregularity on the street at 110 mph and a could feel the wheels spin and loose traction as my TC dash light lit up. The freeway was empty of course (Covid has helped in that regard). The rest of the time home, and for the past few days, I've been driving on the 91 + meth file, 750/750. The car is a monster. But it's also very very well behaved when off boost. It's almost too good to be true. How could a car that has such brutal acceleration and power be able to drive around town without a hiccup? Thank you Sam!!
Here are some observations that may be helpful to those of you who are thinking of this type of conversion:
-The lag and boost response is better and improved compared to my 68VTG's. Stange but true. The lag is not as bad. The 68 VTG were not particularly laggy, but there was some. I know turbo lag BTW. I have a hot-rodded single turbo 930.
-The car is ungodly fast compared to before. That's the obvious observation.
-Here's the one of the best aspects of these turbos compared to my 68 VTG's- with my VTG's, boost would fall off when shifting. When driving fast/aggressively for example, the 3d to 4th gear shift would result in a split second (around a 1/3-1/2 second according to my Racelogic curves) fall off in boost. You could feel it. You'd shift and sit there and wait for boost to start cranking again. This is now gone with these turbos!! The BOV's are quite noisy back there, so they are doing their thing very effectively. But man is it nice to shift and be back on boost essentially instantly. This is a huge huge improvement in my opinion.
-The twin disc Protomotive clutch is awesome. Just a little heavier feeling that my old set up (487pp and LWFW). I love it. It's a brute but feels almost like stock.
-I did a couple quick 60-100 pulls in 3d gear- 2.7 seconds on 91+meth. I did a lazy shift (0.6 second shift...still breaking in clutch) 60-130 and got 6.4 seconds. When I look at my 3d gear pulls of 2.7 seconds, and look at my 4th gear 100-130 time of 3.0 seconds, you get 5.7 seconds if this car were a PDK.... probably faster than that because the car would still be in better powerband up through 60 still in second gear. Either way, it is very fast compared to before.
In summary, I could not be happier with my decision to do the Xona conversion. The car is too awesome to be true. I cannot say enough about Sam Ahdoot and his team. This build is different than most because this was actually done in person by Sam and his team!! I am sorry for the length of this posting- but I hope it sheds some light on some of the potential questions and concerns in doing a non VTG conversion. I am very very happy with it, and I do not see a downside. If anyone is thinking about doing this, I would encourage you to take the jump. And if you are in the western part of the country I would also highly recommend you take the extra time and trouble to send your car to Sam!!!
I will be posting photos. I'll also do a post on 6Speedonline.
Keith
9SIX4-C4 (08-18-2020)
Old 05-21-2020, 07:12 PM
wcarson
wcarson's Avatar
The beast.
e85
Old 05-21-2020, 07:14 PM
wcarson
wcarson's Avatar
Again, a shout out to Sam Ahdoot at ByDesign. The tuning on this car is beyond phenomenal. Smooth as silk when tooling around town and a monster when let out of its cage. Sam was so great to work with, and the nicest guy in person as well. A true asset to our community!!!!
Old 05-21-2020, 07:25 PM
wcarson
wcarson's Avatar
baseline 68VTG (one of the pulls), Xona 91, Xona 91 plus meth
Old 05-21-2020, 07:26 PM
wcarson
wcarson's Avatar
Meth Gauge- Awesome!
Old 05-21-2020, 07:28 PM
wcarson
wcarson's Avatar
Beautiful work.
Front Methanol Tank!!
Quality!
Old 05-21-2020, 07:31 PM
wcarson
wcarson's Avatar
Look at that Weld. Wow. Thumbs up for Sam at ByDesign.
Huge Turbos.
Xona XR1000 business end.
Old 05-21-2020, 09:30 PM
CT944
CT944's Avatar
Wow, impressive. What exhaust are you running?
Old 05-21-2020, 10:05 PM
wcarson
wcarson's Avatar
Thanks! I'm running full GMG 3" exhaust, GMG headers, 200 cell HJS sport cats.
Old 05-22-2020, 03:29 AM
saabin
saabin's Avatar
Impressive setup, after I did my FBO mods but with stock turbos years ago I also got got a baseline Mustand AWD dyno, and had numbers slightly under your "baseline" numbers (535/585 whp/tq) and that translated to slightly slower 60-100 & 60-130 times than you posted..
I have debated back and forth going all-in with it, but in the end I never could pull the trigger.. I ended up getting a Cayman that I drive much more than my turbo and even though the power is not as impressive it is tons 'o fun.
How did you collect your perf numbers? Draggy or Vbox?
I've bought a few parts from Sam before, he will bend over backward to make you happy..
You could have some fun in that thing with the 1/2mile airstrip events.
Old 05-22-2020, 03:43 AM
IMI A
IMI A's Avatar
Thumbs up
Fantastic build and with Sam nice to have US based tuner always at hand at short notice. I think your VTGs were maybe never running properly and they are very hard to tune well on your poor quality fuel. In non sport I run 7.5 secs 60-130mph in 4th gear repeatable all the time and get around 7.1 secs on some runs but 7.5 the average. This drops to 6.5 secs in sport mode (repeatable) both pump runs on Tesco 99 ( I believe UK Shell V power and Tesco 99 far better than US fuel).
With MS109 60-130mph drops further to 5.8 secs. If I build I'm going your route and throwing the VTGs away. I don't bother going to track without race fuel. The difference in trap speed is massive pump vs race fuel. 200mph v 215mph
Very nice to run around at crazy power level all the time I'd go as far as saying the way you have it tuned there isn't a better 911 turbo out there.
Old 05-22-2020, 01:29 PM
wcarson
wcarson's Avatar
Yes, it's a pretty big step to take and it isn't cheap to do all this stuff. I have a Racelogic Vbox Sport as well as a Dragy. To do quick, non-analytical runs, I use the Dragy. When I really want to look at shift times and get a more detailed look at pulls, I use Racelogic. When using both at the same time, the numbers are identical.
Old 05-22-2020, 01:39 PM
wcarson
wcarson's Avatar
Thanks IMI A. I agree, the tuning with VTG's is very sensitive and dependent on good fuel. California 91 is among the worst. That was one of the big reason I finally decided to get rid of the VTG's. My motor was built and that also factored in.
Your times are awesome....obviously your car is running very strong! Overall I am certainly happy with the decision to go for the Xonas. The raw power on tap is really fantastic. I don't track this car, but there are multiple freeway ramps and rural highways on my daily commute, so it's indeed lots of fun!
Old 05-22-2020, 01:55 PM
SamboTT@ByDesign
Basic Sponsor
SamboTT@ByDesign's Avatar
Thanks for the kind words everyone.
Keith, thank you so much for your write up. It’s just a really amazing and fun read no matter how you look at it. I must say, we are flattered and we appreciate you so much. Every day when you text me it makes my day how much you are enjoying the thing. And it reminds me what an awesome team we have and how the components we work with like a family make such a great recipe. It was a pleasure meeting you and your son bud And I’m honored to have been able to help set this up so you can get so much enjoyment out of it!
Proud TOP Porsche Distributor For:
Kline-Innovation - ams Performance - TiALSPORT/XONA - #1 COBB PRO TUNER - CSF - IPD Plenums - DO88 - dodsonmotorsport
310-600-1850 - sam@bydesignauto.com
Old 05-22-2020, 02:11 PM
IMI A
IMI A's Avatar
Thumbs up
This is the dream 997 turbo build guys. Congrats to all involved. I'm concentrating on chassis and brakes next don't need any more power (for now) but this is how mine will end up touch wood. TB993t runs a conventional turbo set up with RS tuning on his GT2 and i suspect there will not be much in it between his build and yours. Think he spent £50K or £100k on his engine alone can't remember! Thats $160,000 in your money. This build comparable to that one IMO and turbo tech moved on considerably with these new XR 1000. Real credit to you guys.
Re fuel yes Ive been looking at you guys 60-130mph scratching my head for years with built motors and VTGS running very similar time to me on a stock engine with big VTGS. Its now dawned on me its your poor fuel!
Sam correct me if Im wrong I thought on your other dream 991 turbo s Pikes Peak build you were tuning using ECU rather than with boost controller? Is this not possible on 997 with conventional turbos.
If Carlsberg did 911 turbos this would be it
Quick Reply: Xona Turbo XR1000 Conversion (ByDesign)- Full Review!
