Tune/Flashing systems?
Hey Guys (and Gals...are There any girls on here?),
Note: My car is a 997.1 TT OEM
I am about to go headers (leaning towards EVOMS, but open to suggestions) and exhaust (EuroPipe stage 2) and a tune. The Tuner/installer I was planning to use (Titan Motorsports, Orlando, Fl., they have the only 4 wheel dynojet dyno in central Fl.) recommended Cobb autosport to flash/tune the ECU. This being my first Porsche I was looking for some guidance on the best tuning software or tuning system/procedures. I would like to be able to put the ECU RAM/"map" back to stock without needing to pull the ECU.
no need for headers. oem headers will handle and flow 1000 hp. unless your using v band turbos save the money for tuning. cobb unit with multiple files will run about 1500$ also look into usp motorsports in fl and protomotive in ar. emre from turkey is another tuner who is a master with the 997 tt platform..
I have a system that tunes and datalogs remotely thru the OBD2 port.
https://rennlist.com/forums/997-turb...-975-00-a.html
Feel free to email me kevin@ultimatemotorwerks.com
I have Kevin's tune and here is some real-world dyno data..
https://rennlist.com/forums/997-turb...-dyno-fun.html
Before doing more work to my car it had a protomotive tune from todd...the car ran great,good power over the whole rpm range
now that I'm running a syvecs Emre/ms motors (the guy from turkey) tuned my car and its out of this world awesome lol. I had my car dyno'ed at AIM performance here in New Jersey who work with Emre for all their tuning
Also if you end up going with a shop that uses the cobb access port. I have a brand new one for sale
Dyno runs are very cool to watch. The numbers always look great with impressive data outputs. The real test is the 1/4 mile run and times. That’s the real deal. I would love to take my car with that FVD tune and run it and see if all the hype is true. Then remove it and correlate the “real” data. Never had the time to do it.
Custom tune; datalog; great support = Ultimate Motorwerks.
Many guys on here are running UMW on their 996 and 997 turbos.
add Edit - Once logged and loaded, can remove tune back to stock in less than 5 minutes.
Skip the headers and save your $. Headers are a must-have adder on small/big block FI/carburetor motors but on your car and for your needs not necessary. There are numerous other components to spend money on and headers are at the bottom of the list. A tune should be at the top of your list along with an exhaust system you are on the right path. EP seems to be the unofficial exhaust choice of our fellow TT comrades. UMW's tune (Kevin) is a favorite at well, alebit, I run another brand. Have fun with it!
+1 for Kevins tune and support, having his tunes on both my 996 and 997 along with many of the other countless things he has help out with.
