6200 rpm rev limit after motor/ ECU change
This is very odd. We ran the new motor and ECU and revs stopped at 6200. The seller said that he never had such a problem. We substituted my old ECU and the motor ran great to redline. We then used the Cobb tune to trim the setting to my exhaust and the 6200 cutoff returned, now on both ECUs.
I'm told that the problem is that the TC module isn't communicating with the ECU. I assume that deleting the Cobb tune was tried early on but I will pass along your suggestion, and thanks!
Terry, what did you put in your car? Still the '07 I saw long ago at NJMP?
