REV Counter
Does it have an aftermarket tune?
You're probably out of warranty anyways but having range 4 or 5 will void any engine warranty items.
Did you put those over revs on the car 60 operating hours ago? If not, did you get a DME readout prior to purchasing the car?
The good thing is that it happened 60 h ago (and only 5 ignitions) and your car is supposedly still fine. I wouldn't worry about it too much and keep enjoying your car. If you track, change and inspect the oil regularly.
Is the price open to negotiation?
Is it a 997.2 GT3 or GT3RS?
Knowledge of the overrev is useful and can be planned for if you can get it at the right price.
If price is marginal, walk away
Is this the car at Marshall Goldman? GT3 RS?
I have read on searches that porsche NA has certifîed some cars even with over rev at range 4. Anybody can confirm this?
If the car gets certified, i will definitely buy it.
A car will not be Porsche CPO'd if it has range 4 and 5 over revs. With that being said, a dealer can sometimes get around it and do it for you, but you need it in writing. I had a 2006 Cayman S that had range 5 over-revs but was CPO'd when i bought it. The engine blew and it was replaced under warranty. The range 5s were there before I purchased the car. I did not get a DME readout when I bought the car. The dealer also claimed that they did not know it had range 5 over-revs when they certified the car as well. Anyways, Good luck!
I passed on a 2011 .2 that was CPO'd at Beverly Hills with range 5. That may be an anomaly; car was two years old, purchaser was not aware of DME or overrevs issue.
