smog test recommendations Bay Area...
title says it all, time to smog test the 7.2 and I'm looking for suggestions from fellow Bay Area RLers for a good place to smog test my GT3 (w/SW bypass)
TIA
- Larry
TIA
- Larry
The current protocol is a test via the OBD as they no longer sniff the exhaust (but you probably knew that). If you are looking for a shop that'll ignore the bypass then I hope a RLer can help you out. I just use my local Chevron and have never had a problem with my stock .2.
Bypass shouldn't matter, since you're not touching the cats. I've had my car smogged twice in San Mateo, both times at a random small Indy shop. I wouldn't worry about where you take it.
GT3 player par excellence
larry, with bypass, you still can pass any where.
but i usually have fremont porsche do it rather than have other smog shop fiddle with my toys.
^ dont worry, you dont live in KALIfornia
