Thoughts on this enclosed trailer
Was hoping to get some feedback on this trailer: http://www.99westtrailers.com/alcom-...7l-car-hauler/
I can probably get it around $11K which I know is pricey, but I'll be towing with a '09 Cayenne GTS so need something light. I know the Cayenne isn't ideal for towing what essentially is a brick but getting a 3rd vehicle isn't practical for me at this stage.
My primary concern is resale given that the brand isn't that well known (same group that makes Mission trailers?), so a bit hesitant to pull the trigger. I'm sure I'll end up wanting a longer one in the future, but this should be enough for at least a couple years.
Appreciate any feedback
That you Kas? Looks like your car. Why don't you bring your Cayenne out and tow my Trailex enclosed w/ GT2 in the back and see if you like it? I actually sold my Cayenne when I switched from Open to Enclosed.
My Trailex is basically same specs at that for weight/length/height etc. Mine just has more dents.
GT3 player par excellence
kas
enclosed Trailex
contact doug at switchcar
enclosed Trailex
Worth the stretch imho
If you are towing with a cayenne and want enclosed then trailex is the way to go
Limited supply on west coast almost guarantees great resale
If you want some local eyes on the used one I would be happy to check it out for you if you are serious about it and owner is amenable
Also. The big flappy side doors help so much with ingress/egress. I'd rather drive it up on ramps then have to winch it in/out every time.
If I bought a new Trailex I'd get their new awning cover on one side, electric tongue jack + 12" box height I think (maybe 6" if I could stand straight), LED lights everywhere.
After seeing all the sweet TPD 24' jobs around here in CA I really want one now for the storage. Not a lot of organization/storage in the Trailex. But the TPDs is way too heavy for the Cayenne. I question if my 2500 Suburuban would be happy with it loaded out @ 10k or so
I would agree with the others that Trailex is the way to go and I tow mine with a Cayenne Diesel.
First, the trailer shown in the first picture would make it hard to get in and out of the car when in the trailer. Trailer has a large side door so you just step in and out.
Second, instead of a ramp gate rear opening the Trailex has 11 foot ramps and the rear door opens up. The door opening up means protection from weather as you load and unload. 11 ft pull out ramps mean less of an incline as you drive your car on and off and far less chance of damaging a low front spoiler.
Third, the Trailex has moveable chocks so it is easy to adjust the load for different vehicles.
Fourth, the trailer is built so you can fully open the driver side car door on even a low slung sports car right over the fender making entrance and exit easier
Fifth, the trailer roof is lower, which means that while you might not be able to fully stand up inside ( I'm 5'9" and can not quite stand straight up) it does mean lower wind resistance while towing which is good.
and sixth you can't beat Trailex quality and customer support. No I don't work for them just rally like their trailers. Started with an open Trailex and moved to the enclosed. so nice to have all tools, tires etc have a place and always in their place. So in goes the car and off you go.
You forgot the best part: it's only 7 feet tall. I was able or push mine into my garage with the race car in it and closr the door!!
It's so light that I was also able to pull it back out by hand and spin it around for easy hook up to my tow vehicle.
So light I had to keep checking the mirrors to see if it was still behind my truck!
Sold it for only 1000 less than I bought it for 5 years later.
kaz, budget is fungible.
