Chunky tire issues...
Any insight to what might be causing the below issues?
Rear left tire.
Michelin Pilot Super Sport
38psi hot after 1 lap cool down.
Happened mid way though the day at Putnam Road Course which is a clockwise track with a pretty coarse surface
Car is aligned to the below settings.
FRONT
-2.0 degrees camber, 0 toe, 8.0 degrees caster
REAR
-1.5 degrees camber, 14 minutes of total toe in
1st pic is of the area circled in blue. Pictures are after driving 200 miles home.
Rear left tire.
FRONT
REAR
TWS (our local track here in Houston) is pretty rough too, but Super Sports have a tendency to do this when ran hard. Problem seems to get worse with lower tire pressures, ie. below 36 hot. Not sure if problem is worse in winter or summer.
Last year I had a all four tires chunked badly after a full weekend leaning hard on them. Took them back to the local tire store, they called Michelin and gave me an 80% credit. 3-4 months later the same happened. No credit...
I have a 2 track weekends coming up and looking for a third so i am going to order a set of tires since they will be needed sooner or later.
My original/ideal plan was to go 10mm wider up front and keep the rear the same but it appears the rear 305 is on back order.....
Is 245/35ZR19 and 325/30ZR19 the plus size everyone gets for Pilot Super Sports?
Op- those tires look real bad. I wouldnt run them at all even for street. Put it on craiglist now for $40 for whole set : ). Jk. Anyway rough surface tracks will do that. Still looks good to go though. I wouldn't hesitate driving them on track. Mike
Jajaja
Ok I have 2 days at the new Corvette Museum track and then two weekends later 2 days at Mid Ohio, then looking to do VIR for 2-3 days 2 weeks after... Since they prob wont last and anyways need to get changed after. If i were to get new MPSS should i get 245/35ZR19 and 325/30ZR19?
