Tried slicks for the first time...
I bought my GT3 new five years ago; in 2007, I took the car to EU Autowerks and had them dial in their famous street/track setup. For five years, I've left the setup the same (EU AW setup and Toyos) and have focused on improving my driving by using the AIM data.
At a few of the local tracks, I feel like I'm getting closer to the limits of the car (vs. my limits), so I decided to have some fun and try a set of slicks for the final event before winter hibernation. A fellow rennlister sold me the used slicks for $500.
The slicks are Michelin N1 cup slicks. They're the same OD as the factory 19" tires and fit perfectly on the CCW 18x9 and 18x12 wheels I use for the track. The rear tires look a bit stretched, and were a pain to mount, but they fit the car perfectly.
I tried them out at Shannonville Motorsport Park. I'll openly admit that I'm not fast at this track, having logged a 2:04 on Toyos a few months back. It's a very technical track and I've only been there a few times, so I'm in full-on learning mode. Every lap is a bit of an adventure with the bumps, surface changes, etc.
The weather was not cooperating at just above freezing, and with a killer wind-chill. Mark Wilkins had recommended I do a long warm-up session and keep a close eye on the pressures. I figured these tires would take 3-4 seconds off my Toyo times once I got comfortable with them.
What came next was a huge surprise. The second lap of the second session was already a 1:58, a full 6 seconds faster than my previous best. The tires were astounding, and they weren't even up to temp! They created an additive effect, with higher cornering speeds, the long gearing was less of a hindrance. I did however struggle to get them up to temp and to keep the pressures happy (30 psi).
In the afternoon, I decided to go for broke to see if I could get enough heat in them for a good lap. It took 7 full-on, sliding, scary laps to get some heat into them such that I could lean on the fronts with confidence and power out without big lurid slides. The lap time dropped another 3 seconds to a 1:55. Even then, the slicks felt like they had so much more to give, if only the temps (and driver!) were more favourable.
When I looked at the data, that feeling was verified by the g-forces being only ~1.3g through the corners, so these were operating like a good set of Hoosier R6's in this weather and this driver. I can't imagine the forces and times with a set on a warm day, and with a driver that is comfortable on them.
Unfortunately, I was not able to improve on that time because I did something stupid at the end of that session. I pulled off-line on the straight to let a group of cars go by during my cool down lap, and picked up tons of OPR (other people's rubber). Once the tires cooled off, this rubber hardened and became one with my tires; as a result, the traction dropped dramatically
I took away a few lessons from this first experience:
1. Tire pressures and temperature are critical with slicks. Even a few PSI above the targeted range and the car would get very tail-happy. Straight out of the pits, with near freezing temps, the car was diabolical scary.
2. The car can be throttle steered so much easier with slicks (probably because the front grips so well now). The steering is so wonderfully light that you can use a very light touch on the steering wheel while producing high cornering loads.
3. The Guard diff comes into its own on slicks; the car could be trail-braked deep, deep into the corners with total confidence. Braking is the area I feel that I under-drove the most on the slicks; there's so much more to learn there.
4. It felt like I was beating the crap out of the car on the slicks, with slapping noises (rubber stuck on the tire slapping the wheel arch), banging (rocks flying up), thumping (rubber stuck on the tire) and every bump and groove on the track filtering through. It felt like my entire car was vibrating itself apart.
5. Going off-line with warm slicks is a bad idea. You'll pick up other people's rubber and ruin the traction of your tires. If you do, immediately take the rubber off before it hardens. Once it hardened, nothing I tried got it off; I couldn't generate enough heat for it to melt/peel off. Any ideas what I should have done?
6. Slicks are extremely addictive; I can't imagine going back to Toyos anytime soon...
A decent lap on the slicks:
Last edited by fc-racer; 11-05-2012 at 07:29 PM. Reason: Images were appearing upside down... the slicks were good, but not upside down good!
Basic Site Sponsor
Basic Site Sponsor
Received 3,175 Likes
Great post! Congrats on finding that amount of time!
Teams use a heat gun to warm the worms and a wire brush or tire scraper.
http://www.fab-worxinc.com/qmpit.html
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
GT3 player par excellence
yes images upside down
is it due to grippy tires?
The only thing better than slicks in certain condition are Hoosier R6 which is great for easy DE and cold weather. Typical "customer" Michelin slicks are not suited for track temperature below 65F and that's when R6 outpace slicks on the same car.
Michelin slicks last and last. I run my slicks way pass 40 heat cycles and they are still decent and fast!
It's nice to have two sets of track wheels - one with Michelin slicks when temperature is hot and looking to out pace other by 2-3 seconds and another set with R6 for cold weather and easy track days
