997 GT2/GT3 Forum 2005-2012
GT3RS 2011 Engine Problems
Old 04-05-2015, 01:24 PM
  #91
Spyerx
Spyerx's Avatar
Received 1,792 Likes on 1,090 Posts
On the .2, 4.0 engines the intake are same part, exhaust are different part. I (think) the .74 engine is the RS4 engine in the PET. .77 is 3.8. I400 option indicates rs parts.
Old 04-05-2015, 03:52 PM
  #92
usctrojanGT3
usctrojanGT3's Avatar
Received 3,995 Likes on 2,276 Posts
Ok so can someone please clarify the part numbers that I need to buy for the intake cam actuators and the exhaust cam actuators?
Old 04-05-2015, 05:21 PM
  #93
RedRSA
RedRSA's Avatar
Originally Posted by surlynkid
Anybody know specifically what Porsche did different with the .93 parts? What makes them stand up to the harmonics better with respect to bolts backing out that loc tite would not do?
I have never been able to find a definitive and authoritative description of what changed between versions. Not that they haven't occurred, but I have not read/heard of failures traced to the latest versions.
My version of PET cites the 997.2 3.8L engine code as M97.77, but it ends at 2011 and does not include the RS 4.0. My guess is that the engine code M97.74 cited above is the 997.2 RS 4.0 engine code. If so, the latest version of the actuators would be:
(2) Intake 997-105-051-93
(1) Exhaust 997-105-053.93
(1) Exhaust 997-105-054.93
When mine were updated, this is what was used.
Old 04-05-2015, 05:23 PM
  #94
surlynkid
surlynkid's Avatar
RedRSA - same part numbers apply for non-RS 3.8?
Old 04-05-2015, 05:25 PM
  #95
RedRSA
RedRSA's Avatar
Yes; mine is a non-RS.
Old 04-05-2015, 05:32 PM
  #96
usctrojanGT3
Thanks RedRSA...I have an RS so do I get the same part numbers (since you have a non-RS)?
Old 04-05-2015, 05:43 PM
  #97
surlynkid
surlynkid's Avatar
USC - you get Cayman parts now don't you?
Old 04-05-2015, 05:51 PM
  #98
usctrojanGT3
Cayman PDK issues resolved and JRZ coilovers going on Monday and hitting CA Speedway on Fri-Sun. No more massive understeer, plowing through turns.
Old 04-05-2015, 06:24 PM
  #99
RedRSA
RedRSA's Avatar
Yes, we all want the good stuff, i.e., the latest RS version.
Note - I did caveat the part numbers based on the RS 4.0 having engine code M97.74; I hope to confirm this/have someone with a 2012+ version of PET verify this. However, these are the parts used in my car.
Old 04-06-2015, 08:17 PM
  #100
RedRSA
RedRSA's Avatar
I called Sunset Porsche today and they confirmed that the RS 4.0 engine code is M97.74. The latest variocam actuators applicable to both the 997.2 GT3 and GT3RS are as cited above (ending with .93)
Old 04-07-2015, 02:01 AM
  #101
kyrocks
kyrocks's Avatar
Originally Posted by vdossant
I have the same variocam engine failure on my 2011 GT3RS. Porsche is not covering it due to over-revs. Has anyone gone to arbitration over this? I'm contemplating it and would like any advice.
This happened to my 997.2 RS. It was 4 months out of warranty. I had stage 1-2 over revs. Porsche covered the bill for a new engine out of "goodwill."
I sold the car soon after that.
Old 05-08-2015, 10:18 AM
  #102
dmaxx
dmaxx's Avatar
Originally Posted by madmurdock
Anyone get a quote to get the actuators replaced?
I just had it done. Here are the parts and cost for both parts and labor. Done by my dealer includes 2 years warranty. Car has 7500 miles on it and no bolts had backed out, but decided to replace with newer rev of the actuators. This was based on discussions with multiple Porsche mechanics, including those @ Barber. All had seen the issue multiple times.
Had a 4.0 clutch, pressure plate, and throw-out bearing replaced at the same time. The shop did not charge for the labor for that since it was being done at the same time.
Old 05-08-2015, 11:26 AM
  #103
p0pey
p0pey's Avatar
Anyone know if they'll replace the bolts through CPO as a preventive measure?
Old 05-08-2015, 02:43 PM
  #104
sin911
sin911's Avatar
Thanks for the detailed info, why does yours start with $4,158? Is that the labor for this job?
Also, should you replace the actuators if the car doesn't have RS LWFW?
Old 05-08-2015, 03:53 PM
  #105
dmaxx
dmaxx's Avatar
Yes, $4,158 is the labor. Don't know about the flywheel. I don't think that is really a factor as the Porsche mechanics I have talked with have seen the issue with other models as well.
Quick Reply: GT3RS 2011 Engine Problems
