997 GT2/GT3 Forum 2005-2012
Monoballs-- which are most effective?
Old 05-20-2012, 08:43 AM
  #31
Nick Wong
Nick Wong's Avatar
No it doesn't. Turning the upper mount is only for those who can't fit bigger tires towards the inboard direction. Why on earth would you want less caster instead of more? Is your car unstable at high speeds? That would be the only reason to do it from a handling perspective- but that can be dealt with better via rake and toe.
Old 05-20-2012, 08:46 AM
  #32
ir_fuel
ir_fuel's Avatar
So you are telling me that Manthey Racing doesn't know how to correctly align a GT3?
I will have a new alignment done soon, I'll see if I can get the numbers (esp. caster) so I can post them here.
Old 05-20-2012, 09:40 AM
  #33
Nick Wong
Nick Wong's Avatar
No, I'm saying that the explanation "Manthey does it" is crap because it does not address anything relevant concerning alignment specs. Of course, if you don't know how or why caster is used then this discussion is moot.
Old 05-27-2012, 03:21 AM
  #34
Nick Wong
Nick Wong's Avatar
So, I was perusing the interwebz today and saw this-
http://www.jzmachtech.com/shells/new...hp?id_news=306
It describes Manthey's suspension setup, where they add one degree more caster to front via ball bearing upper strut mounts.
Even Manthey, whom people think is the-end-all-be-all, and can-do-no-wrong, is adding caster.
Food for thought?
Old 05-27-2012, 11:17 AM
  #35
mdrums
mdrums's Avatar
Food for thought?
Also interesting that they use 9x19 and 11.5x19 with 235 and 325 tires.
Old 05-27-2012, 11:42 AM
  #36
M3EvoBR
M3EvoBR's Avatar
Originally Posted by bmardini
LCA or thrust arms?
Example?
You can buy Porsche Motorsports lower control arms with Cup inner monoballs.
Those are the one that you need. Add solid thrust arm bushing and you're good to go.
You can also buy the ones from GT3RS, but than you will need the inner monoballs.
I should have a few dozens of them
Old 05-27-2012, 11:44 AM
  #37
M3EvoBR
M3EvoBR's Avatar
Originally Posted by ir_fuel
Turning works perfectly fine. Had my car alignment done by Manthey Racing last year and first thing they asked was if I turned the top mounts already. If not they would have to do it.
Sure it works, you go with different top mounts, and also solid adjustable thurst arm bushings, and then you're ready to go.
Stock car, everything stock ???
No No.
Old 05-27-2012, 11:50 AM
  #38
Orbit r
Former Vendor
Orbit r's Avatar
We work on those cars for longer that we can remember. Also a couple of our mechanics came from Manthey, and not to say that we are Manthey dealer in the US. There is no mystery on its geometry, but there are a few ''things'' that can be done to improve handling, and rotate the struts in a non modified suspension is not one of them. If you need more clearance for tires, you can always change shocks, top mounts, lower control arms, bushings and so.
Old 05-28-2012, 11:20 AM
  #39
Mvez
Mvez's Avatar
The car is noticeably crisper with the rear LCA monoballs, tested them this weekend at Mid-Ohio.
Old 06-27-2012, 04:28 PM
  #40
ir_fuel
ir_fuel's Avatar
Car went to Prospeed competition last week:
http://www.prospeed.be/
These guys participate in races such as the Le Mans 24h with pilots such as the not too shabby driving Sean Edwards
I asked them to check the alignment and I also inquired about the pro's and cons of turning the top-mounts. The response was quite clear. It is a good idea to turn the top-mounts if you want to do a track alignment. There is no problem with the caster whatsoever and it is the easiest way of getting enough camber in the front.
Now if Manthey says so, and Prospeed Competition says so ... who am I to doubt this?
Old 06-27-2012, 05:47 PM
  #41
Serge944
Serge944's Avatar
Rear toe links and forget about it. Even the dog bones aren't necessary.
Old 06-27-2012, 10:42 PM
  #42
Mvez
Mvez's Avatar
+ these. Then forget about it. There's a reason the 4.0 gets them from the factory. I'm a believer after using rear LCA monoballs. Tarret makes a great piece, super easy to install.
http://www.tarett.com/items/996-997-...996-detail.htm
Old 06-27-2012, 10:58 PM
  #43
Izzone
Izzone's Avatar
Giesha is mono everywhere, I threw the entire tarrett catalog at her
Car takes a set a bit quicker
Tire wear is much better
Old 06-27-2012, 11:09 PM
  #44
Mvez
Mvez's Avatar
The front monoballs are next. I apparently love paying for alignments.
Old 06-27-2012, 11:12 PM
  #45
mdrums
mdrums's Avatar
...and all are TSB updates so car remain stock, right?
Quick Reply: Monoballs-- which are most effective?
