Sunroof Delete Complete
#107
#110
Were they able to remove and replace the headliner without removing the back half cage? I have the Tequipment half cage and would like to get the sunroof removal done also. I'd like to remove the headliner myself before I drop of the car at the shop but I'd hate to have to remove the roll bar in order to do this. Thanks...
#112
I haven't weighed things, but I did see the parts. The sunroof part of the roof (metal only) felt like it was 20lbs, the original roof was heavier then the roof skin it replaced, plus the motor, track, and all the other little sunroof bits. only saving 24.7lbs, I doubt it. I based the weight savings off a thread that Gomez did, and he weight all the parts that came out and replaced it with a CF insert were the roof was. Perhaps the 996 guys numbers were off, who knows my project is done, and I am happy to have a lighter weight, non sunroof GT3.
#113
Congrats on the completion. Thanks for the clarification on the weight savings. I should see if the shop that did the work still has the sunroof insert.
#114
Well, I just did the sunroof delete mod on my car and the weight saving after all was said and done is right at 26lbs, give or take a few ounces. I weighed all the pieces that came out and that's what I came up with. The part numbers are the same on the 996 and 997 cars as everything is superceded to a 997 part number now. In regards to the weight of the sunroof part of the roof (metal only) as referenced above, it feels very heavy indeed but it actually weighs right at 10 lbs when on the scales. It's very easy to inflate the weight savings (wishful thinking I guess) but the reality is this mod using the factory 17lb solid skin will net a savings of 26lbs. I'm still glad I did it as the weight is coming off the top of the car, you get more headroom inside, and the car looks much cleaner on the outside. Great mod....
#115
#116
Was at shop and they were doing this to a turbo and used the RSR (I think?) carbon fiber/kevlar skin. Stupid light and not that expensive PMNA part all considered. Will need to be with installed with roll bar. Anyone else use this vs. the steel skin?
#120
Thanks for the details in this thread... 7 years later, and the thread helped me complete the sunroof delete on my 997.
A few people have asked me about the sunroof delete, so I am sure a bump of this old thread wouldnt hurt
pics of my car after the sunroof delete and fresh paint...
