Go Pro
I picked one up over the winter and will be trying it out this weekend at Summit
The rennline hook's a bit off-center when mounted to the front bumper. The true direction of the car is somewhere between 10 & 11 o'clock in your resultant videos...
What kind of seats do you have? If you have the "regular" seats with the hook in the back you can try this... I just put this together for my 997.2 S so I can mount my GoPro right behind the seat.
Bought an extra plastic hook piece for ~$10, and screwed a 3/4" square stick of wood onto it (painted it gray). The GoPro is held on via a tripod mount that is bolted on the end of the stick. Vibration isn't bad, more due to the play in the seat than the mount/stick. Might try mounting the camera closer in to see if that helps.
Everything is attached by screws/bolts, but I wouldn't put anything weighing more than a GoPro or bullet cam on this.
^ I applaud the ingenuity of your design, but having a loose object like that is a safety hazard on track. I for one wouldn't want a stick located THAT close me or my passenger's head/neck area...
I can see from your pic that you probably don't have a better location to mount behind your seats (absent a cage). How bout a dash suction mount? Alternatively, velcro to the back of your mirror?
But I do see your point about it being a stick. Will probably shorten it anyway to reduce vibration. And I'd point out that it's only a few inches more forward than a roll bar.
Just to note for me personally, my primary track car is the 6GT3 which has a roll bar, seats, and 6-points. So for me, this contraption in the 997.2S is not for hard core track duty anyway.
