WTB: Center Lock Wheels GT3RS fitment
My CCW 18" wheels where 9" and 12" wide so i'm positive I can also fit this width under the GTS.
I have a call into Damon at Tire Rack to see if I can get this sorted out.
What many people don't get or understand is the GTS is a widebody car...same dimensions as a Turbo and GT3RS. The CL wheels on the GTS are 8x19 and 11x19 same as the Turbo or the 5 lug wheels on the GTS are 8.5x19 and 11.5x19 and show different offset numbers. The offset will change as the wheel width changes. The 12x19 offset is 48et on all these cars. Tire Rack shows the front width on CL's for GT3 and Turbo as 51et on 8.5 wheel with 235's but since the GT3RS uses a 245's Tire Rack shows a 9" wheels with 51et offset. I believe the offset number changed with the width of the wheel.
You compare wheels... you want your replacement wheels to sit in the same spot (outer edges) as your OEMs and maintain enough clearance from suspension... Your thinking about it the wrong way... Use an offset calculator to help you get it right...
Congrats on the GTS, Mike! Every one that I've driven so far — even a Cab! — has been flat-out brilliant.
Coupe with Sport PASM was a bit much on Michigan, livable but only worth it if I was going to do track stuff all the time. In other words, I suspect that's the way you went.
pete
pete
mdrums, if you want to get this right, you need to forget about what body your car has... frankly you don't know where your hubs are placed in relation to the edges of the body compared to those of an RS...
@ mdrums
Thanks - the RS Spyder wheels in sliver (I hate the whole black with silver lip thing) are awesome on your GTS - can't wait for picss of the real thing with the aerokit.
My issues would be the upfront costs for the tools vice what I have on hand, as well as the smaller and more expensive selection for track wheels, but no deal breaker.
Much less concerned abouth the safety of them as they've been used and "abused"
by the best here on RL.
From the Porsche site here is the dimensions of the stock 5 lug wheels for a wide body GTS or Turbo.
8.5x19 et 55
11.5x19 et 50
I just also spoke to Damon at Tire Rack, extremely personable, knowledgable and nice.....and he said the 12x19 et48 on the rear will work but suggested to stay with the 8.5x19 front et51 since I'll be useing a 235 tire over trying to put that size tire on a 9" wheel.
After I talk to my dealer to see if they know anything about if the GT3RS has a wider front track than a GTS and Turbo I'll you you know....I'm thinking the RS might have a wider front track....we'll see.
pete
pete
Mike, Try some GT3 and RS wheels first. Both OEM and aftermarket. There should be plenty around that don't mind swapping wheels. You can also chak out the look and stance better.
Maybe driving over to my place is a good way to break it in and we can try my OEM and BBS wheels?
be careful. There are two versions of CL, the one used by the GT cars, and the one introduced in the 911 Turbo now used in the GTS and Turbo S.
In regards to wheel width and offset, the 3.8 RS and GT2RS wheels sizes fit the Carrera GTS just right.
Sin911, a typical rookie error is to buy NT-01 or RA-1 at full tread, shaving is your friend with these two tires. Don't blame the smaller diameter, that actually helps you more by reducing your long gearing.
What everyone says is the front diameter is supposed to be smaller than the rear in a 997, that's my concern. And most 18" tires don't have that
You have some tolerance built into the ABS computer for diameter difference front/rear, nothing to do with ICE mode (Do Search on my id). I got abusive ice mode in the 997 GT3 RS running Michelin slicks on similar diameter as stock tires, and very little running a massively bigger street rear tires and a shorter front tire. My Cayman running 24.9" front and rear tires produces Zero ICE mode despite of running much taller rear tires stock.
Anyway, running 245/305 RA-1 on 18" is just fine with any 997 (from Carrera 3.6 to GT2 RS), they stick more than the stock rubber.
My dealer just emailed me the GTS and GT3RS PET pages on wheels/CL nuts and hubs and spindles. Anyone good and this stuff PM me your email and you can take a look too.
actually they don't last as long at full tread, because they get chunky and out of a decent round shape due to chunks. The cheater guys in Florida shave them way too much. 5/32" is just right.
The RA1's are fine for sure, I've been running them with no problem. But the overall diameter on the 305 tires are taller than the 245
