Stainless steel brake lines
After a few weeks of ownership of an '11 GT3, and a track weekend, the nit-picker in me has finally emerged. I still find just about everything about the car brilliant. The only fault I find is a somewhat soft brake pedal feel when driving casually. I've got the PCCBs and the braking power, and the modulation, and "hot" brake feel are fine. Wondering if SS lines would help pedal feel in "regular" driving. I've read that Cup cars have the same lines as OEM, that SS lines are a waste of $ and time, and the like. Objective performance is not the issue, it's that I like a firm pedal when driving casually. Also, for some reason I'm finding it difficult to find SS lines that fit the '11. Thoughts solicited.
Doubt it'll make any difference whatsoever in street driving when your brake fluids won't be anywhere hot.
I'd argue that the braided steel lines help only when you expect the fluids to get really hot, to the point of softening the OEM rubber tubing.
Change to decent fluid and make sure that they're properly bled. Stock pads go away quickly with steels after track use, not sure about PCCBs
I have steel brakes. I had this feel of soft and long pedal travel this past weekend at Summit Point. There are plenty of pads left on all corners, plenty fluid (no boiling), but the pedal travel has double basically.
After several sessions, even with cool down half-lap, when I parked the car the brakes were smoking, literally. Granted cooling can be improved probably, but level of softness and pedal travel took away some of the confidence while on track. I was thinking of SS lines, it won't hurt, but probably will not change the feel noticeably either.
Hmm. Since replacing the stock brake fluid (first mottul rbf, now castrol srf) and going to pagid RS29 pads I've had no issues except normal disc rotor wear. The stock fluid and pads were terrible as things heated up and they really seemed to eat the rotors as well. If you use em, they're going to get hot, smoke and eventually the calipers will change color as well....a badge of courage. I guess I haven't heard anyone on this forum make a case for SS lines, but I probably am missing something. You are obviously an experienced driver so let us know the outcome.
It was a really cold weekend too, 38-40 at max, so I am a little worried. I was using Motul 600 and Yellow RS-19s. We'll see how this progresses, hopefully not through a tire wall
I was going to get SS brake lines but some real honest people that could have sold me them said on a newer car like mine I'm wasting my money. The stock brake lines are good lines and it will take a while for them to degrade and soften up.
I use Motul RBF660, Pagid RS29 Yellows front and RS14 Blacks rear and stock rotors. Sebring is tough on brakes and I have good stopping power and no fade really.
My guess is that the SS lines are not going to help a lot, especially for what I'm talking about -- pedal feel on cold brakes. Still, used to have a 964 w/ Big Reds, but with C2 master cylinder (which can produce a mushy pedal due to mismatch). The SS lines did help a bit with pedal feel in all conditions, but it wasn't night and day. The lines/fluid are relatively cheap compared to other things we do to these cars.
I just did this mod but only because I was having the calipers rebuilt anyway. Interestingly, it appears that 19 of the 20 ceramic insulators on the tips of my pistons were missing. Anyone else have this happen? I know that they didn't just fall off during pad changes so I assume they deteriorated over time.
