997 GT2/GT3 Forum 2005-2012
New GT3RSR
Old 12-11-2010, 01:30 PM
LastMezger
LastMezger's Avatar
Default New GT3RSR
NEW PORSCHE 911 GT3 RSR FEATURES NUMEROUS UPGRADES
World’s most successful GT race car enhanced with revised
aerodynamics, suspension and engine
December 11, 2010 --- At the “Night of Champions” party held at the Porsche R&D Centre in Weissach to mark the end of the motorsport season, the 2011 version of the world’s most successful GT race car celebrated its international premiere.
The Porsche 911 GT3 RSR enters the new motorsport season with extensive modifications. Further development prioritized newly designed aerodynamics at the front and rear as well as changes to the suspension kinematics and the engine.
The 4.0-litre, six-cylinder boxer engine now delivers 455 hp at 7,800 rpm, five horsepower more than its predecessor. The power increase results from an engine management system which adapts even better to different fuel grades, as well as a redesigned exhaust system and a modified air intake housing. Moreover, the drivability of the famously efficient engine has undergone further improvements. Maximum revs remain unchanged at 9,400 rpm.
At the front of the car, a new front lip provides higher downforce at the front axle. The front wheels are now larger, with the rims growing from 11 to 12 inches wide, providing additional front-end grip and reducing understeer. The position of the rear wing and the shape of the wing mounting were also optimized and harmonized with the design of the new rear fairing with additional air outlet louvers. The rear lid was also redesigned for optimized air ducting. Like the 911 GT3 Cup and the GT3 R, the RSR is now equipped with the LED rear lights taken from the latest 911 road-legal cars.
The 911 GT3 RSR joins the 911 GT3 R and the 911 GT3 Cup as the top model of Porsche Motorsport’s product range. The successful long-distance racer from Weissach can be ordered a price of 410,000 Euro plus country-specific value added tax. All 2011 modifications are also available as a kit for GT3 RSR cars from the 2010 season.
Technical description Porsche GT3 RSR (2011 model year)
Engine: Water-cooled six-cylinder boxer engine; 3,996 cc; stroke 80.4 mm; bore 102.7 mm; 455 hp (335 kW) at 7,800 rpm; max. torque 450 Nm; air restrictors 2 x 28.6 mm; max. revs 9,400 rpm; four-valve technology; dry sump lubrication; individual throttle butter-flies; fuel injection.
Transmission: Porsche six-speed gearbox with sequential jaw-type shift; oil/water heat exchanger, single-mass flywheel; hydraulic disengagement lever; three-plate carbon-fibre clutch; rear wheel drive; limited slip differential 45/65 percent.
Body: Monocoque body (based on 911 GT3 RS) of hot-galvanised steel; aerodynamically optimised front end with front spoiler; aerodynamically optimised front underfloor; adjustable rear wing; 90-litre FT3 safety fuel tank with fast filling function; air jack; welded-in safety cage; race seat (driver’s side only) with flame-retardant upholstery; six-point seat belt adapted for use of the HANS Head and Neck Support; electric fire extinguishing system.
Suspension: Front McPherson spring strut axle; Sachs four-way gas pressure dampers; double coil springs (main and auxiliary); front axle arms adjustable for camber; adjustable sword-type anti-roll bar; power steering. Rear multi-arm axle with rigidly mounted axle sub-frame; Sachs four-way gas pres-sure dampers; double coil springs (main and auxiliary); rear axle tie-bar reinforced and infinitely adjustable; adjustable sword-type anti-roll bar. Complete suspension infinitely adjustable (height, camber, track).
Brake system: Brake system with balance bar control. Front single-piece six-piston aluminum fixed calipers; inner vented, 380 mm diameter; racing brake pads. Rear single-piece four-piston aluminum fixed calipers; inner vented, 355 mm diameter; racing brake pads.
Wheels: Front three-piece BBS light-alloy wheels (12J x 18 ET 34); central bolt. Rear three-piece BBS light-alloy wheels (13J x 18 ET 12.5); central bolt.
Electrical system: Motec display with integrated data recording; multi-function display with integrated gearshift indicator; adjustable traction control; battery: 12 volt, 80 Ah, 140 Ah alternator.
Weight: 1,220 kg
Old 12-11-2010, 01:38 PM
silverboy
silverboy's Avatar
Love it.
Old 12-11-2010, 01:40 PM
911SLOW
Admin
911SLOW's Avatar
I will read the specs later and post but for now ...
Old 12-11-2010, 01:43 PM
LastMezger
LastMezger's Avatar
So...definitely not street legal right?
Old 12-11-2010, 01:50 PM
ritzblitz
ritzblitz's Avatar
Front lights look a little FD RX7 ish.
Hopefully this can hang with the Ferrari.
Old 12-11-2010, 02:04 PM
Wilder
Wilder's Avatar
Received 5,006 Likes on 1,776 Posts
Sexy beast.
Old 12-11-2010, 02:12 PM
tcsracing1
tcsracing1's Avatar
how much longer will this platform be used once the new platform hits the showrooms?
Old 12-11-2010, 02:17 PM
FFaust
FFaust's Avatar
Ok, now I think I need a cold shower.
Old 12-11-2010, 02:40 PM
cfjan
cfjan's Avatar
Interesting to see that the 4.0L engine makes 455hps, while the street car 3.8L from the RS is rated at 450hps.
And the 4.0L is allowed to rev up to 9,400rpm as well.
So either the 455hps rating is probably very conservative? Or it is simply tune for more torque and not much power w/ the bigger displacement?
Old 12-11-2010, 03:19 PM
996FLT6
996FLT6's Avatar
^rsr has restrictors on specs. Wonder how much hp if unrestricted. Mike
Old 12-11-2010, 03:35 PM
911SLOW
Admin
911SLOW's Avatar
500+ PS easily : )
Yes sure it will FIFY. : )
Old 12-11-2010, 03:36 PM
ADias
ADias's Avatar
Smashing!
Old 12-11-2010, 03:41 PM
trophy
trophy's Avatar
12" wide fronts..... WOW..
Old 12-11-2010, 04:12 PM
Spyderidol
Spyderidol's Avatar
Until there is a 991 GT3 RS for homologation. Most likely not until 2013.
Old 12-11-2010, 04:20 PM
Mspeedster
Mspeedster's Avatar
The FD RX-7 had pop-up headlights that where square-ish in shape when up. I'm not getting how you see any RX-7 in the RSR.
Anyway, love new the GT3 RSR!
Quick Reply: New GT3RSR
