Gen 2 GT3RS petrol warning light issue
Was out running the new car in. Petrol light chimed and I checked the on board computer which said I had 53km left. One minute later, car loses power and some how I manage to roll across 6 lane highway (I was on the Sheik Zayed Road - truly NOT the place for this to happen) and pull onto hard shoulder. Turn everything off and then trun car over - it's trying to fire but nothing. I'm thinking i've run out of fuel..... but confused as to the 53km the computer told me and the fact the warning light had literally just come on.... I walk to the garage and buy petrol can and petrol and walk back (lose about 7lbs in weight - nice way to save weight for the RS). Get the fuel in (with the ingenious use of sunglasses (use the arm to keep the flap open). Waited and then fired her up and (thanks be to Allah) the green baby starts.
Anyone else had this problem? - I can't believe the onboard was so wrong and that I ran out immediately after the car's warning light and chime came on.
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
i have been down to 20km left on two occasions. one being full laps on the ring. other being autobahn at 280kph+ driving to next esso station. no problems and well past the initial fuel warning light.
how do you run low on fuel in Dubai? i would figure there is gas station every corner.
Only thing that's possible is if you were on full throttle for less than a minute after the light came on. I would imagine anything full throttle could guzzle up gas rather quickly.
Anyone else had this problem? - I can't believe the onboard was so wrong and that I ran out immediately after the car's warning light and chime came on.![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
That's really wierd....
My 996 Turbo would sometime stay empty on the gauge after I would fill up and from memory I think that it had something to do with the float marker remaining at the bottom of the tank rather than rising.
LOL x 2!!
no way. full throttle has definitely been applied and you wouldn't run out of fuel that quickly.
