Question regarding flipping pads
I've read on multiple threads about people flipping their pads in order to more evenly wear them.
Am I correct in assuming that the pistons will compensate for the uneven pad, keeping the full surface area of the pad on the rotor, thus having no effect on braking?
Kush
Kush
I'm pretty sure you flip the pads to extend pad life, not increase braking power.
Immediately after flipping I would say braking force is compromised until the pads re-seat to their new position. If bevel is severe, I have even experienced a spongy pedal until re-seating has occured.
What's the concensus on these pads? I was flipping them today and noticed that what looks like rivets are starting to show through on the right hand side of the left pad.
I'm going to go get new ones tomorrow (I've got some P50s but I'm going to wait until next year to install them since my track work is done for the year).
Keith
Keith
Generally if lining material is down to thickness of backing plate I replace the pads. The rivets start to show about that same time as well. And then the pads start to make unhappy noises the thinner they get.
PCCB rotors especially start getting cooked (begin delamination) if you track and lining gets thin. Then your brake job get exponentially more expensive
X2. Though at that point they will probably work fine on the street for a while longer, the loss of mass reduces the caliper's ability to dissipate heat, and the pad will become much more susceptible to fading under heavy braking. I can usually tell when my pads are getting to this point on the track because of sponginess developing in the pedal feel.
For DD use flipping is a great option... I would not do it myself for heavy Track / Racing... When my track pads get below 1/2 to 3/4 used... I pull them and keep em' for spares to DD with.
