Mk 2 RS Track Alignment How much Neg Camber?
#32
I'm guessing something like -3 front and rear for the 2010 RS on R6's.
-2 front and rear was "enough" but not optimal and -2.5 is their stated "minimum."
-2 f + r was good for Sport Cups.
With Mac struts, I'm surprised -4 worked at all. Maybe with street springs and sways?
10 celsius range -- what was the inside temp reading?
#33
Admin
John
#34
Still plays with cars.
-2.5 front and -2.5 was very good with Hoosiers R6, but too much in the rear for RA1's.
I am going to flip the rears on the RA 1's (Outside still virgin) and try -1.8 rear.
When I had -1.8 rear on the Hoosier R6, I had some outside wear.
My fronts wear perfect booth Hoosiers and RA1.
#36
Track - I had 2.4 neg rear ad corded the inside edge of the R6 Went to 2.2 neg and all was/is well. The 2.4 worked well on the narrower 996 GT3 tires. The 325s on the '10 RS need less negative camber because they are wider
#37
Yes, camber is pretty delicate with 335's in the rear. Even wear on R6, crazy uneven the next day with RA1's.. I thing maybe the RA1 is stiffer and "gives" less + less overall grip.
The hoosiers corded down the middle, so perfect. Put new RA1's on, 2 seconds faster and absolutely no tread wear outside 30% of tire! Same track, same day.
#38
That's on R6's presumably.
Stock Suspension
inside was approx 73 degrees C or 163 F
#39
what size hoosier slicks are you using?
i bought spare 19" rims and cantget a hoosier slick.
the Michelin 19"s are very expensive and i think only go to 290 wide.
anyone with experience here?
#40
ive run no less then neg 3 ront and rear on a 7GT3 for years. i never once chorded a tyre on the inside. my tyres heat cycle out before i chord them.
#41
#44
Hmmm. I have 345 Hooters on the back of the 10 RS. Sounds like I might step it up from -2.0 to -2.2 and the same -2.2 on the fronts (265/19's.) What's the rear toe? I assume zero or a smidge toe-out front.
#45
Time to bring this thread back from the dead. Anyone with any updates? I don't really hear too many going as high as -3 up front. Range seems to be -2.5 to -3 front, -2.2 to -2.5 rear.
Car is getting set up for next season and I want to start fresh. I have a friend who is running -3f, -2.25R on a regular 997.2 GT3 and he thinks the car feels great. Will likely be using some Hoosiers and some Pirelli Corsa/MPSC/Trofeo. So what do you think?
