Voltphreaks 5.5 lbs lithium-ion nano battery
#61
Admin
Since this thread is revived:
These guys are amazing I bought a VPH900 and they honored their RL discount even after it had expired. (Thanks Mike for the tip )
Also their service is excellent! after some problems I had with the first battery (it didn't crank the engine as strong as I would like it) they did change it under warranty and also gave me for free the stronger more expensive model of the line VPR-P6 which works great.
Now if only all companies we deal with worked this way we would all be in a better place.
#62
Cheers
#63
Did someone develop a clip/retainer for this battery?
#64
Admin
Don't think so but it's an easy DIY and can be done with several ways. The battery is small and light so you have room to work there and you don't need any heavy duty brackets.
For example I used a plastic top bracket. and two hooked studs with butterfly openings.
#65
I found someone who will custom make me Lithium type batteries to any spec CCA's for a chunk less than 1300! Plus they weigh 4.5lbs or less! I've ordered one one to try out that will be here in a few weeks, and will keep posted!
#67
Make sure they will have electronic to prevent over charge related explosion or fire
#68
#72
I see that the retail price on the VPH750 battery has been lowered to $999. Be interesting to see if VP will offer a discount for a group buy. Would be very tempting !
This is becoming a more attractive mod.
#73
I'd suggest adding the necessary lightweight tie-down bracket, maybe an isolator ground terminal and an appropriate tender to keep the battery healthy -- these things are all necessary anyway, so the collective up-sell is a win-win.
#74
Former Vendor
I own a version of this in my KTM bike - niiiiiiiiiiice unit. When you flood the bike after a drop, etc - the cranking power is unsurpassed....in a bike here however. FWIW. The thing is unbeleivably light.
