Same furnace but different price? PCCB comparison
#31
Former Vendor
Here's the data for 996 GT2 ( and GT3 too. I still suspect that there's a misprint concerning front disc diameter, IIRC it's still 350mm ).
4 Chassis and suspension 911 GT2
4 - 8 Service Information 2001
Brake system, general
The 911 GT2 is equipped with the new Porsche
Ceramic Composite Brake (PCCB) only.
The main advantages of the new system are:
• 50% reduction in rotating and unsprung
masses compared to conventional brake discs
with the same diameter (911 GT2 is 16.4 kg
lighter than 911 Turbo)
• Fast brake response
• Maximum fading stability owing to constant and
high friction coefficients
• Excellent responsiveness in wet conditions
• Long service life of brake components (brake
disc up to 300,000 km/185,000 miles)
Front brake
Brake disc
The front brake disc has a diameter of 360 mm
and is 34 mm wide. The brake discs have involute
internal ventilation and are perforated.
The brake discs are bolted to a separate stainlesssteel
carrier. The disc and carrier should, however,
never be separated. The vehicle type (GT or Turbo)
and the direction of rotation are indicated on the
carrier.
Note
The ceramic brake discs are sensitive to knocks
and impacts. The brake discs must never be
knocked (especially at the edges) when they are
mounted and detached. This also applies when
wheels are mounted.
Brake discs with chipped edges may still be used
provided that the damage does not exceed a
certain tolerance. Refer to the information give in
the Technical Manual.
Brake calliper
The tried-and-tested single-piece aluminium brake
calliper is also used for the 911 GT2 (the GT2
version, however, has six pistons).
The piston diameters vary according to the
direction in which the brake disc rotates through
the brake calliper. The piston diameters are
28/32/34 mm.
The brake calliper is painted yellow.
Brake pads
The brake pads are made of a special metal
composite material which ensures high and
constant friction coefficients when combined with
the ceramic brake disc, and has a long service life.
Two damping elements are attached to the carrier
plates. No other damping devices are necessary.
Brake pad wear is monitored.
Rear brake
Brake disc
The rear brake disc has a diameter of 350 mm and
is 28 mm wide. The brake discs have involute
The brake discs are bolted to a separate carrier.
The disc and carrier should, however, never be
separated. An arrow on the carrier indicates the
direction of rotation.
Note
wheels are mounted.
Brake calliper
version has four pistons).
28/30 mm. The brake calliper is painted yellow.
Brake pads
Brake unit and brake hydraulics
The diameter of the brake master cylinder is
25.4 mm. The boost factor of the vacuum brake
booster is 3.15.
And then a quote from 2004 GT3 Technical Manual:
PCCB (optional)
Right from production start, the 911 GT3 can be equipped with the Porsche
Ceramic Composite Brake (PCCB) as an option. This is the brake system which
is also installed in the 911 GT2.
Technical data
• 6-piston monobloc aluminium fixed callipers at front
• 4-piston monobloc aluminium fixed callipers at rear
• Brake callipers painted yellow
• Carbon-fibre-reinforced ceramic brake discs with evolute cooling channels, drilled
• Disc diameter 350 mm front and rear
• Disc thickness 34 mm f ront, 28 mm rear
• Brake pads specially adapted to ceramic brake discs
(front axle P 90-2, rear axle P 90-2 painted yellow)
So, would someone please make hats that have 996' dimensions but Brembo/Corvette bolt pattern?? Without Porsche Tax! All you need ( except 20mm spacers for rear calipers ) in addition to correct pads to make them work, if you just can cope with incorrect caliper colour...
EDIT. 380mm CCB's would be nice, but in my case it would mean changing 3 sets of wheels from 18" to 19". 350mm's preferred.
Front brake
Brake disc
carrier.
Note
wheels are mounted.
Brake calliper
28/32/34 mm.
Brake pads
Rear brake
Brake disc
Note
wheels are mounted.
Brake calliper
Brake pads
booster is 3.15.
PCCB (optional)
Technical data
#32
#34
Hi Mikymu,
I am sure some of the Brake Specialist could dismantle the ZR1 caliper,
Powder coat/Paint it to color and emblem similar to stock Porsche and then rebuilt the ZR1 caliper.
In 1993, I buy a Brembo Big Brake kit
for my Lexus GS300 through a speed shop that sourced it from Stillen.
At that time Stillen was the official distributor for Brembo for USA market.
The caliper is the F40 style caliper,
and it came in black color from Brembo.
and since I want it to have the same gold color
as the Brembo Racing Gold Line caliper,
I have the caliper Painted Gold with red Brembo lettering on it. It looks nice and withstand the daily use too. so I am sure you can do the same to the ZR1 caliper.
also at that time, there is no ready to use Big Brake Kit,
and each time people order for their car,
Stillen would have to measure the car and custom made the bracket for the caliper and the hat for the rotors. The hat was floating design too.
Mine was the first Lexus who ever have a Big Brake Brembo Kit installed.
I am using the original Lexus rear disc and caliper,
and have no problem with the brake bias, so Stillen did a good job that time.
and it was a 14inchs rotor or 13.8 inchs (I forget now)... and the Lexus GS 300 stop much much faster than the original factory brake... and the ABS work just fine.
the problem was the rotor start to crack near the crossdrill holes after only about 10,000 km of hard street use, even though the pad still have plenty of material...
but the hat and other custom part are doing just fine...
again I remind you that all the above custom work was done in 1993, and if it can be done at that time,
I am sure it can be done better in year 2010 hehehe...
I spent $5,000 for the front custom made kit
including install and cross drilling the rear oem brake rotor,
and the stainless steel braided line for the rear brake...
but come to think of it, that $5,000 really save my life many times, hahaha
I was young and drive a bit too fast at that time...
by the way Stillen is the distributor for AP Racing brake product now,
and they might be able to custom made a hat for your ZR1 rotor conversion.
Here is the Stillen subsidiary for dealing with AP racing product website :
http://www.brake-pros.com
and here is another website of a seller who use
to sell many Brembo but after some business dispute,
he change to sell Stoptech product.
But he know a lot about Brembo and I think he can service Brembo too, so since ZR1 caliper is made by Brembo,
maybe he can have solution for you:
http://www.zeckhausen.com/
He is a great guy, and I communicate with him several time by e-mail in the past.
and mikymu,
talk about rain and flood on Southern California,...
I just open Jalopnik.com and they have story on this Rain and flooding,
and on the main pictures they have a pictures of Lexus GS300 on flooded Freeway
(I think this is the 10East going from Freeway 1 (PCH right)) ?
What a coincidence, because I just talk about my old Lexus GS300 on this post few minutes ago... and you just talk about
rain, and there is a picture combining your story and my memory hahaha
below is the picture:
I remember this kind of flooding in LA also happened in 1994 or 1995 while I was studying at USC...
do you remember that one ?
and mikymu,
I know Dave zeckhausen well. Great guy and super helpful!
I left LA in 1993 after graduating from UCLA so I miss the flood. This past week has been nothing short of horrible as far as rain goes
#35
Thanks for the detail info and your brake mod. Very impressive. If push come to shove I may look into the ZR1 to GT3 RS brake mod but it will take alot of modifications including wheel selection to fit the gigantic rotors.
Wow, you study in UCLA,
although I study in USC,
My apartment was on Wilshire just 3 blocks from Westwood... We might actually met before, hahaha
anyway,
I have another info for you:
http://www.gmgracing.com/porsche_brakes.shtml
if you go to the most bottom part of the webpage above from GMG racing, you will see that GMG actually offer Brake Caliper Painting Service,...
so just in case you have to use the ZR1 caliper,
than you can let GMG paint it for you and change the logo into Porsche logo
below is what GMG say:
GMG offers brake caliper painting service on used or new brake calipers. A very quick process which can be scheduled and done in one day. If your calipers are old and in need of some new life we can restore them to there original finish and quality. We can also paint calipers to any color you choose. Examples are Yellow, Silver, Black, Red, RS Orange and more. If you have a custom color in mind or are interested in color matching to your car this is also available. All calipers are available with the Porsche lettering in white, silver or black. We use a high temperature paint and special non yellowing clear coat.
All work done at GMG, mail order customers can ship there calipers in to have the work done. Turn around is just a few days and your calipers will be like new!
Please contact us for pricing.
#36
#38
Hi Mikymu
anyway,
anyway,
Oh yeah, I used to live on Hilgard right next to UCLA sorority row ... those were the good old days. Thanks for the link. Caliper color don't bother me - they all become black any way
#39
Rather than trying to adapt the rotors and mounting bells from another vehicle, I suspect you'd be better off having a set of carbon discs made up to the original specs and sizes by these guys
http://www.surface-transforms.com/
They're available in sizes up to 410mm dia from Movit.
You'll find a brief explanation as to how they're manufactured here too.
http://www.movit.de/rahmen/ceramic.htm
And here's a few images of them fitted to my 996 GT2
Rear installation
Rear Disc
Front Disc
As for the costs, the original PCCB rotors were expensive and time consuming to produce, The reliability issues experienced when they were first released were due to overheating issues. Subsequent refinements to the internal venting (and an increase in disc diameter) have improved the longevity of the products considerably.
They do have their limitations however. The wearing face is extrely thin, and once worn it can deteriorate and start to delaminate. This exposes the substrate the wearing faces are bonded to.
The substrate beneath has an incredibly coarse texture and is very hard, once exposed it wears through the friction linings in a matter of miles.
The ST discs however are formed using a different manufacturing process which means they're construction is homogenous. For the record, they're the suppliers to Koenigsegg.
They won't delaminate and if the surface should get damaged (by a trip into a gravel trap or a stone getting trapped between a wheel/caliper and the brake rotor) then the face can be reground and the rotor re-used)
As for the expense of the original PCCBs, when they were first announced Porsche AG were of the opinion they would last 120,000 miles.
I'll allow someone in the US to do the math, but how many sets of rotors and pads could a hard driven street car expect to use in 120,000 miles ?
Add in the labour to replace them for your average Porsche owner (ie one who lets his Porsche dealer fit them as opposed to DIY) and see what figure you come up with.
I drove my 996 GT2 with both the original Porsche steel 350mm discs and the ST carbons. The difference in unsprung weight is staggering and the difference in how the car behaves on bumpy roads had to be experienced to be believed.
With the heavy steel discs fitted to the car it was prone to understeer, the steering was heavy and responses through the wheel rim dulled.
With the carbon discs fitted the steering was lighter, less understeery and far more "pointy" and the front end was so much more planted over mid corner bumps.
Don't underestimate the benefits of carbon rotors for road use.
I've no affiliation with Movit or Surface Transforms btw
Rear installation
Rear Disc
Front Disc
#42
I purchased mine directly from ST some 3 or 4 years ago as they wanted a development car to trial fit the rotors to. This is no longer an option as the european rights to supply them have been secured by Guido at Movit.
I'm not sure if StopTech have similar intentions for the US. I suggest you drop Guido at Movit an Email for costs
#43
#44
Atgani, just to be clear, you have carbon-ceramic rotors, right? Not carbons.
As for the weight of the things, I would love to know what your rotors weigh because from the look of it, they will weigh more than PCCB due to their construction. I would guess 7 kg?
I saw these rotors on a Z06 at Hockenheim last year and on that occasion they looked pretty thrashed with much deeper pitted areas than when PCCB´s go bad. I understand the argument that they can be resurfaced, but obviously at that time and on that car they had to be eating pads like a chainsaw.
#45
Movit is not a viable alternative for PCCB. I just got a reply back form them. You need to use their carbon ceramic rotor, caliper and pads and the whole thing cost more than $20K!!!
