PCCB to GT3 Cup steel rotors - bitter sweet conversion
#61
This is what the 997 TT PET (E_997T_KATALOG.pdf) says:
997.1 TT (upto 2008): Rear Brake Disk Left: 997.352.405.01 and for the Right: 997.352.406.01.
997 GT3 PET (E_GT3-2_KATALOG.pdf) comes up with exactly the same part#'s for the steel rears..
I thought the steel GT3 rear disks would not fit the 997.1 GT3 PCCB set-up...
#62
![](http://img9.imageshack.us/img9/1915/pict8999.jpg)
#64
![](http://img571.imageshack.us/img571/9424/pict9795.jpg)
#68
Mikymu, thanks for the feedback on the zo6, what pads have you found to be the best so far I have just started AX with it and will be visiting the track soon to see how it compares to my 6gt3.
Mike
Mike
#70
Hi there
Maybe you guys can help, I've got a 997.1 C2S which has PCCB upgrade, so 350mm rotors all round.
I am converting back to steel, is it the 997 Turbo rotors which are a direct fit for my car please?
I assume the larger GT3 380mm front rotor is not compatible due to wrong offset?
#71
Hi there
#72
#73
edit..997tt iron discs fit
#74
#75
