GT3.2 Lift system
#46
Bottom of spoiler to ground is the same for MkI & MkII...
#47
I previously owned an '07 997S with factory aerokit. I'm actually scraping less with my new '10 GT3. I think it is a combination of the shape of the lip and the firmness of the suspension.
Example - I park in an underground garage with a steep driveway that flattens out abruptly to the flat parking area. The driveway is narrow so I can only take it with a slight angle. The 997S always scraped. I can get the GT3 in with no scraping.
I have scraped while driving and unexpectedly hitting an uneven spot in the road. The lift system will do nothing to stop this. So based upon my experience, I don't see the need unless you have trailer issues or problems with your home driveway, etc.
#48
Received 1,888 Likes
#49
I have decided to order the front lift system to help increase the usability of the car. Sure, 30mm isn't huge but it is the difference between just scraping or damaging you bar because of an aggesive angle. Many driveways and carparks are narrow so angled approaches aren't an option. I don't want this to decide whether I take the car or not...
The car will still scrape but my aim is to make the car as usable as possible.... Keeping in mind that the front lift increase the approach angle of a gt3 almost to that of a regular Carrera. The price is steap but the price of the car is steaper- shame not to be able to use it as much as possible.
#50
The car will still scrape but my aim is to make the car as usable as possible.... Keeping in mind that the front lift increase the approach angle of a gt3 almost to that of a regular Carrera. The price is steap but the price of the car is steaper- shame not to be able to use it as much as possible.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
#51
Increasing the usefulness of the car is absolutely a good thing. Although, a gt3 is lowered 30mm more than a standard Carrera, the gt3's front (even lifted) will still scrape where a base Carrera would not. The gt3's front lip is angled much differently than a base Carrera. A gt3 raised 30mm at the lip compared to a base Carrera at its' lip, the gt3 would still be lower.
Front spoiler scrapes are a given in a gt3. If it means I can actually take it places I would otherwise avoid like the plague- its gotta be a positive.
#52
ok the bilstein airlift is in. I have some pictures but they are not great. here is what I can tell you. it does a very nice job of raising the car almost 2". It is a funny system that uses the porsche supplied tire air pump that is in your trunk to fill the air bags. you do not replace the springs, you raise the upper spring perches by 13mm. this is all that is needed to accomodate the unfilled airbag. you do need to completely remove the shock to get to the camber plates and upper perches. The compressor makes a lot of noise from inside the car, outside you barely hear it. it takes around 15 - 20 seconds for the car to get to full height. also the little remote they give you is a little annoying as there is no hardwired button in the car, just a little keyfob. other than that it does exactly what it is supposed to. lowered ride height has not changed at all.
#53
The Cargraphic flyer shows a switch available in roof console, guess you did not get that option.
What was the Total Labor cost? Did that included re-alignment and resetting ride height ?
#54
I'm betting a lot of people will get sick of waiting 15-20sec after a few weeks and will just scrape the crap out of the car just to get where they are going.... Way too long to have to wait... Can't exactly crawl slowly towards a set of speedhumps waiting for the car to raise before you get there... What about when you're pulling into a service station or your driveway (assuming on a busy street)? Do you wait at the entrance whilst it inflates, holding up traffic behind you...
I'm seeing more drawbacks with some of the aftermarket systems than the Porsche system dispite the greater clearance...
#55
Is it worth $3k? Is the whole car worth $130k? I don't know. The point is that the lift system is a very, very worthwhile feature for those of us who enjoy daily driving our GT3, and has little to do with preserving the front lip.
#57
Jonesy always with the info. That's a pretty neat installation (assuming it somehow retains at least one garage door button pair.)
#59
the hardwired button is not available yet, and the labor is 5.5 hours plus alignment. if you know where you are going, like when I get close to my garage in the city I press the button ahead of time so when I get there it is already at full height. you can do this as long as you are not going above 30 mph. the KW system was $1000 more, not sure how that one works.
